  #21 (permalink)
Old August 2, 2010, 08:04 AM
martin_metal_88's Avatar
Originally Posted by jcmaz View Post
You forgot the Azza Helios 910 or the Solano 1000 which can be had for <$100 after MIR
Are they longer??? Because the HDD are mouted in the same direction so if they are not bigger then it's no go. That's the problem with the 902. When you put a big card some HD have to be kicked out.
Build Opinions icecoals New Builds 45 May 6, 2010 04:12 PM
upcoming build, some guidance please ccm001 New Builds 24 March 5, 2010 12:05 PM
Upcoming I5 Build Bucklaz New Builds 9 September 24, 2009 12:44 PM
New upcoming build HaDeS New Builds 8 September 16, 2009 06:43 AM
First post, upcoming build Realityshift New Builds 35 March 9, 2009 08:12 AM
