Old August 1, 2010, 03:42 PM
Post Any thoughts/suggestions for this PC build
Mobo: Gigabyte P55A-UD3 ATX LGA1156 P55 DDR3 2PCI-E 2PCI RAID GBLAN CrossFireX USB3.0 SATA3
Processor: Intel Core i5-760 Lynnfield 2.8GHz 8MB L3 Cache LGA 1156 95W Quad-Core Desktop Processor
Heatsink: Noctua NH-U12P SE2
Graphics Card: GTX 470 EVGA 012-P3-1470-AR GeForce GTX 470 (Fermi) 1280MB 320-bit GDDR5 PCI Express 2.0 x16
Ram: OCZ OCZ3G1333LV4GK 6GB DDR3 3X2GB DDR3-1333 PC3-10666 CL 9-9-9-20
Case: Antec Three Hundred Illusion Black Steel ATX Mid Tower Computer Case
PSU: OCZ Z-SERIES 650W 80+ Silver Certified 24PIN
TV Tuner: Diamond TV Wonder 650 Theater PCI-E TV
I like the looks of this system but any suggestions would be greatly appreciated...
Old August 1, 2010, 03:47 PM
not a great of the 470's bang per buck.
same with the antec case. look for a lianli or cooler master in the price range +-10-20 bucks
corsair,seasonic for psu
edit maybe a PS05B as well for choice.
Old August 1, 2010, 03:53 PM
which video card would you suggest?
Old August 1, 2010, 04:15 PM
+1 for the Corsair,Seasonic PSU's and CM cases!
I would go for a Corsair HX650 as its modular, meaning easier cable management over non-modular units as you only use what cables you need.
For cases I suggest looking at a CM 690 II, Basic or Advanced, or a HAF 922 or 932.
With your ram, I recommend going with G Skill, Corsair, Mushkin or Patriot.
For your video card, you can stay with the 470, but I would recommend going with either of the EVGA GeForce GTX460 versions, the 768MB or 1GB for better bang for buck as _dangtx_ was leading up to.
Everything else looks good, good luck with your build
Old August 1, 2010, 04:23 PM
stoanee's Avatar
You have picked a triple channel ram kit for a dual channel board. A popular pick for ram are the G-Skill ripjaw series. The 470 is a solid card but the 460 is a better value for slightly less performance. I would go with a Coolermaster Cm690 II case, a good value.
heatware
Old August 1, 2010, 04:30 PM
Perineum's Avatar
Maybe consider the Xeon X3440 processor for the Hyper Threading...
right on.
http://tpucdn.com/reviews/Zotac/GeFo...es/perfrel.gif
a bit of oc which all the gtx460 seem to live to nv's promise so far :)
http://tpucdn.com/reviews/Zotac/GeFo...perfdollar.gif
http://tpucdn.com/reviews/Zotac/GeFo...es/perf_oc.gif
basically clock it well and you get a 470 or so. of course power figures will go up, not a lot if you dont touch vgpu
Old August 1, 2010, 05:27 PM
fishingfanatic's Avatar
Smile New Builds
I agree with the others. The psu Corsair. Video card EVGA 460 1gb. Case Coolermaster 922/932. Memory Mushkin, Patriot,Corsair or G Skill. Mushkin is my preference.
Good luck with the build and enjoy the new system!
Old August 1, 2010, 07:02 PM
how can i tell if my motherboard supports triple channel memory or not?
Old August 1, 2010, 07:54 PM
If the number of RAM slots on the board is a multiple of three then it supports triple-channel memory. Otherwise, it doesn't. Also, right now only LGA1366 motherboards have triple-channel RAM support.
$2500'ish (broken budget already, 3K now) Gaming Build - Suggestions/Thoughts? Caldezar New Builds 57 August 15, 2010 03:23 PM
Thoughts on this build? Ghlin New Builds 9 December 11, 2009 06:54 AM
Thoughts on my I7 build thunderstruck67 New Builds 24 August 14, 2009 10:38 AM
New here and a new build any thoughts bobiseverywhere New Builds 20 January 29, 2009 02:03 PM
Platform Advice/Suggestions/Thoughts ev0styLe New Builds 17 December 19, 2008 07:21 AM
