  #21 (permalink)
Old August 16, 2010, 10:29 AM
Originally Posted by Zero82z View Post
How is it for what? And the PSU is garbage.
I thought the psu might be garbage. It may not be worth it. I am thinking of holding out a little longer for a better deal.
Newegg.com - OCZ GameXStream OCZ850GXSSLI ATX12V v2.2 and EPS12V 850Watts Power Supply 100 - 240 V CB, CE, CSA, UL
  #22 (permalink)
Old August 16, 2010, 10:30 AM
I also don't see the Shellshocker deal you were referring to. It's showing a headset.
  #23 (permalink)
Old August 16, 2010, 10:35 AM
if you dont load it to its rated output 24/7 youll be fine. its not like a seasonic that says 850 on the box and it does 850 on the 12, like other 1000+ psus cant do 700 on the 12 :)
