Old July 30, 2010, 01:59 PM
No, you don't need to buy a separate network card. All modern motherboards have built-in ethernet controllers so you can connect to wired networks. However, if you want to connect to a wireless network then you will need to buy a card for that.
If you have a SATA DVD burner then there's no need to buy a new one. However, if it's an IDE model (it'll have a big black connector on the back with metal pins sticking out, in case you didn't know), then I recommend that you pick up a SATA burner just to make your life easier when it comes to setting everything up.
New Gaming Build, First Time Builder OnionFily New Builds 17 June 30, 2010 11:53 AM
First time builder needs help BootlegUsher Troubleshooting 33 February 24, 2010 07:28 PM
first time builder amg New Builds 25 June 25, 2009 11:52 AM
First time builder, 500$ budget PC rapmaster New Builds 34 March 9, 2009 08:14 AM
First Time Computer Builder Looking for Help on $1500 Rig Wein13 New Builds 20 September 9, 2008 07:35 AM
