Old July 28, 2010, 08:36 AM
Should I have them assemble it for me? I don't have the tools or the time to do it..
though I am not sure if they will do it as it should be done
Old July 28, 2010, 08:43 AM
SKYMTL's Avatar
HardwareCanuck Review Editor
NCIX's assembly is supposedly pretty good.
Old July 28, 2010, 08:53 AM
bissa's Avatar
you only really need a screwdriver and some thought, looks like it is fairly straight forward build, no sleeving, no water cooling, so it should go together like lego if you think about it and check the manual/internet whenever you get stuck.
Strong like hummingbird, swift like oak.
Old July 28, 2010, 08:54 AM
Dar_ell's Avatar
The best part (well to me) is actually building the rig myself, if you can squeeze any time in your day I'm sure your going to enjoy it.
"My brother is dead. He's not here Anymore. But on my back, and in my heart...He lives on in me. I will make a hole through heaven itself, even if that hole becomes my grave. As long as I break through, I will be victorious.Who the **** do you think I am?"
Old July 28, 2010, 09:00 AM
I chose to do it my self
now waiting for the price matching so see what happens
Old July 28, 2010, 09:07 AM
bissa's Avatar
good choice, and even if you don't have the right screwdriver (if you have tools, you will) then you can pick one up for a few dollars at any local hardware shop. if you do go buy any tools, get a screwdriver set or a multi bit screwdriver since it makes it that much easier to make sure you have said tools.
it also teaches you how to repair any items that may burn out.
Old July 28, 2010, 09:48 AM
steers's Avatar
Yep, a #2 Phillips and a pack of zip ties will take you a looong way in assembly and basic cable management. The zip ties aren't strictly necessary, but it's surprising how much neater and more manageable your whole setup can be with a few strategically placed ties, especially in the HAF where you have lots of room to manage your cable bunches.
Balthasar - Loop: EK Multi 150 > MCP655 w/X-Top2 > Feser X-Changer 360 w/3x Panaflo 68cfm (push) > Heatkiller 3.0 > EK-FC275 > EK-FB Classified
Caspar - 2x Xeon E5504 | SuperMicro X8DAi | 12GB DDR3 | Radeon HD4850 | CM ATCS840
Melchior - Rev. A MacBook Pro | 2.0GHz Core Duo | 2GB DDR2 | Radeon X1600
Bob - Core i3 530 | Gigabyte H55N-USB3 | 4GB DDR3 | Corsair H50 w/ TFC Triebwerk | Silverstone SG06
Old July 28, 2010, 09:58 AM
martin_metal_88's Avatar
I am sure if you do it like you should that it's giong to be accepted and you will be abble tot ake tons of pic for us in the workblog section of the forum! I second the option of building it yourself and that you will need the previous item listed by another member. But there is something that you HAVE to do or it can go terribly wrong. READ THE MANUEL!!!!! Especially for the ram. How many time a week people post here my first build no post and ram stick are just in the wrong channel...
Ask for more
Martin_metal_88
Colenzo : See system spec!
Odysseus : I7 860 @ 3.6Ghz || GA P55-UD5 || G.skill Ripjaws F3-16000 2000Mhz 2X2GB || Coolermaster ATCS 840 || Silverstone Strider plus 850W || WD 640 black - WD 1TB green - Samsung F3 2TB || MSI 5670 1GB Cyclone ||Coolermaster Hyper 212 + ||
  #19 (permalink)
Damn taxes, its at 2260 CAD..
I guess I will have to go ask for the tax back since I am not Canadian (visitor) any idea how?
  #20 (permalink)
Old July 28, 2010, 10:17 AM
Varroa's Avatar
I don't think you can ask NCIX for the tax back since they have already charged you but you can ask the Federal Gov for it back. I have never done it but I know it is possible.
Visitors to Canada
GAMER: Win7 Pro x64, I7 3770 (stock) (CM 212+), Asus P8Z77-V Pro, XFX 6950 2GB, Corsair Vengeance LP 4 x 4GB DDR3 1600Mhz, Crucial M4 120 GB + 256GB, Intel X25-M 160GB, 1TB WD Blk, DVD, BRD, HX750W, Auz X-Fi Prelude, Intel Pro CT Gbit NIC & CM Cosmos
Game Server: Win7 Pro x64, AMD Phenom II X4 960T Zosma, Gigabyte GA-MA770-UD3, 2x2GB Gskill DDRII 1000, 640GB WD Blk, 1 ODD, Asus 9600 GSO, Intel Pro PT Gbit, Corsair 400W PS & Antec 300.
Motorola Milestone: to buy or not to buy... bojangles Mobile Computing 25 May 14, 2010 10:36 PM
To buy a 5850 or not to buy... pulling my hair out over this 0o0 Video Cards 20 January 15, 2010 01:42 PM
Where to buy from in the UK? somecanadianguy Off Topic 0 December 8, 2009 09:01 AM
Were to buy? Hanibal{CA} New Builds 3 November 15, 2008 06:00 AM
