Old July 20, 2010, 02:36 PM
lowfat's Avatar
Originally Posted by martin_metal_88 View Post
Drop the H50 for a good air coller and change the Maximus for other board. 230 for a Matx board is useless and to much. You can get a P7P55-M for much cheaper. EVGA, Gigabytes and even Asus have cheaper board that can do the same.
The case has limited height for a CPU cooler so his choices are quite limited.
The Crippled God WIP
Queen of Dreams WIP
Big Lian Li
Complete
Forever Alone Complete
Old July 20, 2010, 03:16 PM
or he could get a nuce scythe low profile if need be.
Old July 20, 2010, 04:26 PM
martin_metal_88's Avatar
Prolimatech have the samuel 17, scythe have plenty, thermalright have some to. There is manylow profile or small cooler that are good on the market. And since the H50 need some mod I would stringly suggest to look for a solution that fits in before thinking of drilling the case.
Old July 20, 2010, 05:42 PM
CORE's Avatar
@kruzn4evr
Thanks for the heads up!
@lowfat
I was scouring the bowls of the internet awhile ago and found out that theres some case modding required. Thanks for the reply though.
@martin_metal_88
The asus maximus gene is 220ish but I found site selling it for 170ish. I'm going to price match(hopefully it gets accepted). Also, If I really can't think of any way to put the H50 in the case, I might just aswell go with air cooling using Noctua NH-CP12.
On a side note... I was thinking of mounting the H50 on the Corsair 650W since the fan of the PSU is directly below the CPU. I was thinking of removing the screws for the fan of corsair and mounting the H50 in a push/pull config. However, I don't know if it is a good idea to do so.
Thanks for your suggestions.
Old July 20, 2010, 05:59 PM
Not sure about pushing Hot air from CPU into PSU. That's just my opinion but for me the PSU is THE part I don't want to break. Remember thatwhen a PSU die it can go with the restof the PC. Just a tought.
Old July 20, 2010, 06:45 PM
its been done before, but not that directly lol. remember when on your old pc the psu fan was probably the only one throwing hot warm air from the case out?
Old July 20, 2010, 08:04 PM
Nope. Not a good idea.
Critique my build ModdKid New Builds 18 July 28, 2009 04:54 PM
Critique my first build Bond007 New Builds 15 June 25, 2009 11:06 AM
please critique this build klaiboi New Builds 17 June 27, 2008 07:41 AM
New Build Critique ErroneousFrog New Builds 17 April 25, 2008 08:12 PM
New build - need critique! guinness CPU's and Motherboards 12 December 4, 2007 04:14 PM
