Primarily gaming, with the odd picture editing
Around 1000
Canada all the way, baby!
4. IF YOU have a brand preference. That means, are you an Intel-Fanboy, AMD-Fanboy, ATI-Fanboy, nVidia-Fanboy, Seagate-Fanboy, WD-Fanboy, etc, etc, etc, you get the picture.
No real preference
No carry over from previous one
Yes
Possibly will experiment with mild to moderate overclocking (stable, 24/7 overclocks)
In the next couple weeks
9. What resolution do you use?
1920X1200
So far:
CPU: Intel Core i5 750 (~200)
Mobo: Asus p7p55D deluxe (~160)
GPU: Geforce GTX 460 (~200), possibly a second one in the future
Case: Cooler Master 690 II (~70)
Hard Drive: 1TB Western Digital either caviar blue or black
PSU: either HX 650W (~100) or Seasonic m12d 750W (~130, because the 120 off is so tempting ...)
RAM: Either 4gb of DDR3-1333 or DDR3-1600. Can I get away with cheaper 1333 if I'm only moderately overclocking?
CPU cooler: Cooler Master 212 (~20)
CD-reader: combo cd/dvd writer (prob 20-25)
Thanks for reading!
