Old July 18, 2010, 04:04 PM
Default Opinions on my dream build
Mostly gaming, internet browsing here and there, watching movies, etc (by etc I really don't mean anything else. Maybe some video and photo editing here and there but that's it really)
I tried not to go over $1500 on the parts + extras
Canada
4. IF YOU have a brand preference. That means, are you an Intel-Fanboy, AMD-Fanboy, ATI-Fanboy, nVidia-Fanboy, Seagate-Fanboy, WD-Fanboy, etc, etc, etc, you get the picture.
I'm definitely an AMD/ATI fanboy. I can't help it
I'm keeping my monitor, speakers and my printer
I've been doing tons of research
What kind of a gamer would I be if I didn't plan on overclocking?
Probably within this year or next year. Depends on when I get a job and if a certain mother lets me use my debit online
9. What resolution do you use?
Nothing higher than 1600x900. That's what my monitor recommends as the optimum resolution
So here's what I had in mind. Any input on this computer that may or may not even get build is much appreciated
Case: Cooler Master Storm Sniper Black Edition - $142.46
(I hate the look of the HAF. Too bulky :|)
GPU: Sapphire Radeon Toxic HD 5850 - $352.98
(I plan on buying another one later so that I can crossfire)
CPU: AMD Phenom II X4 955 Black Edition Quad Core Processor - $169.33
Mobo: ASUS M4A89GTD PRO/USB3 - $159.84
RAM: G.SKILL F3-12800CL9D-4GBNQ PC3-12800 4GB 2X2GB DDR3-1600 CL9-9-9-24 240PIN Dual Channel Memory Kit - $97.41
PSU: Antec Earthwatts 650W PSU - $77.54
HDD: Western Digital Caviar Black 500GB HD $57.99
ODD: LG GH22NS50 Black 22X SATA DVD Writer - $21.55
OS: Windows 7 Home Premium - $99.99
These are just other things that I want to get.
AMC: Zalman CNPS9900A LED CPU Cooler - $58.32
Keyboard: Logitech G15 Keyboard - $96.49
Mouse: Logitech G500 Mouse - $67.70
Total: $1,458.09
I'm well aware that in the future some of these prices can/may/will go up or down, but this is what I had in mind for the time being. I also know that when I'm ready to buy all this some of it might not be available.
Any suggestions?
Old July 18, 2010, 04:13 PM
Keltron 3030's Avatar
If you wanna crossfire, might I reccommend a 750W PSU. A 650 CAN do it, but having that extra headroom is always good. Plus I assume you will be overclocking the CPU.
The GPU is good, but just get yourself a reference design 5850. Could save a couple of $$$.
Get yourself a bigger HDD. You'll thank yourself later.
the case is all opinions, but I would reccommend the 690 II.
Also look at the Hyper 212+ for your CPU heatsink. Add some nice fans to this and you got a kickass cooling solution for cheaper than that Zalman cooler.
That's all I got to say.
FFFFFFFUUUUUUUUUUUU-
Old July 18, 2010, 04:18 PM
Your prices are all on the higher end, you can get most of that stuff for a good bit cheaper if you look around.
Try some pricematch search engines:Shopbot - Compare prices - Canada - Price Comparison - Comparison Shopping
PriceBat.ca - Search & Compare Canada Online Store Prices Before You Buy
PriceCanada.com: Search. Compare. Buy. - Canadian Online Shopping Search and Comparison!
There's a few good sites that don't show up on those search engines though, like Bewawa.
I'd recommend you order from NCIX and pricematch, free shipping usually isn't too hard to get a hold of.
The 5850 is WAY overkill for your resolution btw. I'd also look into investing in a really good power supply so you can keep it through component upgrades. The Zalman cooler is a bit overpriced for its performance level, go with something like the CM Hyper 212 or the Gelid Tranquillo, both can be had for $20-$24.
Old July 18, 2010, 04:26 PM
What card would you recommend for my resolution then?
Old July 18, 2010, 04:32 PM
You can get away with something like a 5770, (which destroys most games at 1680x1050) or you could get the new GTX460 that looks extremely promising. The 460 will be a bit more, but the 1GB version should be able to handle a monitor upgrade.
I would either cheap out on the video card and put it towards something else or bite the bullet and upgrade your monitor.
Old July 18, 2010, 04:34 PM
Lpfan4ever's Avatar
I'd have to go with a giant no on that.
I'd guess you're most likely not going to be upgrading for a while due to not having a job, I'd say go for a big card now. Once time goes on, it'll be able to keep up better than something like a 5770. I ran a 4870x2 on a 1680x1050 monitor, and was happy I did because I upgraded my monitor and my old GTX260 wouldn't have been able to keep up.
Originally Posted by encorp
Code:
<firebane> slightly used
Old July 18, 2010, 04:58 PM
expensive case, gpu
dual gtx 460 for the win, at the moment. 922 case wise. cmII to save a few more bucks. maybe quad not needed. psu as above.cm212+ ftw again
Old July 18, 2010, 05:47 PM
Nvidia cards..
Btw: What's the difference between these 2 storm sniper cases? Why is one cheaper than the other?
Coolermaster Storm Sniper Black Edition Mid Tower ATX Case Black 5X5.25 5X3.5INT 1X2.5 No PSU - DirectCanada
SNIPPER 5BAY TWR BLACK ATX ATX/M - DirectCanada
Old July 18, 2010, 05:53 PM
Lpfan4ever's Avatar
Nvidia cards..
One is a SKU for the stock DC has (top one), and the other is a manufacturer SKU, for which I believe DC does not have stock on hand.
Code:
Opinions on this build? squilliam New Builds 4 May 8, 2010 01:28 PM
Build Opinions icecoals New Builds 45 May 6, 2010 04:12 PM
New Build - Need some opinions! bedouin New Builds 24 March 9, 2009 09:12 PM
New Build - Opinions Please. Loejack New Builds 12 September 17, 2008 01:24 PM
