Old July 14, 2010, 11:46 AM
Originally Posted by SwarleyStinson View Post
Thank You!
Switched over to the XFX 5870 and also changed to an HX 750 watt corsair.
Good choice.
Old July 15, 2010, 12:31 PM
dr_dream's Avatar
- Gigabyte X58A-UD3R @ $230
- Intel Core i7 930 @ $300
- G.Skill 6GB (3x 2GB) 1600MHz CL8 @ $170
- 2x Gigabyte GeForce GTX 460 768MB @ 2x $200
- Corsair F60 SSD @ $175
- Samsung F3 1 TB @ $80
- Samsung SH-S243N @ $24
- Corsair HX850 @ $180
- Cooler Master HAF 932 @ $140
- Thermalright u120eXtreme @ $64
PC-Waves.com
Old July 15, 2010, 02:24 PM
CroSsFiRe2009's Avatar
I think you nailed pretty much everything there. I'd personally change the motherboard to the P6X58D-E though just for the better slot spacing.
Old July 16, 2010, 12:19 AM
Sorry I haven't had any responses in a while. had a few busy days.
Will this be better than everything I have chosen? if so, Awesome! and thank you very much for your help.
Trying to get this all figured out by sometime late august early September. so I have a bit of time before I decide. trying to see all the options I have.
Old July 16, 2010, 06:42 AM
-InfiniteLoop-'s Avatar
The only thing i would change is the PSU. For the 2 460's i don't think you need anymore then a Corsair HX750 as the 460s do not support tri-SLI.
Cheers!
IL
Old July 16, 2010, 08:24 AM
fishingfanatic's Avatar
Smile New Builds
+1 for the P6X58D-E. It gives the slot space, good support for gaming with the chipset and while I haven't looked at the Gigabyte board, this one offers new usb and sata 3. I have this board and find it easy to work with. In the end it's your choice. Good luck, enjoy the build and the resulting system!
Tags
desktop , ffxiv , final fantasy xiv , gaming , noob
Building a lew system for gaming LacrosseTown New Builds 4 May 9, 2010 09:33 AM
Need Help Building a Gaming Rig for $800 mr_syn New Builds 13 January 10, 2010 04:47 PM
Building a gaming computer help xargon805 New Builds 22 December 22, 2009 08:40 PM
building gaming pc, need some suggestions happybunny New Builds 26 January 4, 2009 08:16 AM
New to PC gaming. Requesting help building a rig. Zippoh New Builds 19 November 2, 2008 09:35 AM
