Old July 6, 2010, 05:03 PM
Default Bang per fps
any kind reviewer with some time on his hands wanna try something, whenever they care to?
keep some parts the same, like memory, video card,psu,etc. the only difference being mobo+cpu
low end : 240+giga matx vs e3300+giga matx , mid end : , high(er) end :
and work it up form there.
resolution 1920x1080, fixed. eye candy : well, it depends on video card benched in the mix
why go to the trouble, may you ask? just look at the number of threads :)
itll show ppl they dont need to spend 600 bucks on mobo and cpu alone to be able to play games at a decent resolution/eye candy level.
Old July 6, 2010, 05:06 PM
You may want to specify what decent is.
Myself personally 30-40fps is not decent; 50+ is and since you won't see more than 60 anyways due to lcd technology..
I'll speak up and say that a e3300 @ 1920x1080 with full on eye candy will be a definite limiter in fps.
I saw little increase in fps going from a e6600 to a e8400 but saw a HUGE increase in going from a 7900 to a 8800GT.
And being that the e3300 is a celeron.. will hurt it even more.
Old July 6, 2010, 05:09 PM
reason for the thread would be to give people and idea.
say you got an 800 dollar budget. what do you get? a 240 and 5870 or a quad or dual intel and a 5770? :)
Old July 6, 2010, 05:11 PM
dual obviously. you'll see very little performance increase in games between a quad and a dual unless the game will take advantage of that.. and how many games take advantage of a quad these days? efficiently?
Old July 6, 2010, 06:13 PM
jcmaz's Avatar
errrr... I would go for Phenom 945 + 5850 :)
-Plato
Old July 6, 2010, 06:36 PM
at least theres some agreement in here lol.
was expecting worse :p
Old July 6, 2010, 07:48 PM
dustin1706's Avatar
Check out the HWC charts!???!?
Crysis CPU Benchmarks - HardwareCanucks Charts
Old July 6, 2010, 08:39 PM
Crysis
800X600, Medium Settings
DirectX10, 64Bit
well not that game at that resolution going to give you a decent idea. one needs at least 5-10 titles :)
Old July 7, 2010, 09:56 AM
JD JD is offline
Concept is great and all, but nobody is going to do that. Takes way too many hours to put something like that together in a fair, unbiased way.
I'm guessing it takes the fine people at HWC at least 24h of work to put together a GPU review. Multiply that by say 10 different GPUs, then multiply that by 4 "base" systems? Looking like a solid month work.
Old July 7, 2010, 10:21 AM
well, using just 5770/5850/5870 at the beginning would be a great start.
my idea is that the more you spend on mobo+cpu, the less bang per buck you get. sure, fps will be higher, but when you do the math..hehe :)
Big Bang Help Jamula66 Troubleshooting 19 May 13, 2010 02:24 PM
Best bang for the buck dante1 Video Cards 15 December 31, 2009 11:10 AM
Best bang for buck? ImAPC Video Cards 5 September 18, 2009 02:31 PM
Bang Your Head WolfBane Off Topic 28 June 16, 2009 02:18 PM
Bang for the buck g10 New Builds 8 August 13, 2008 11:19 AM
