Old July 5, 2010, 07:28 AM
Trial Member
Default New first build! any final advice?
Motherboard: Asus P7P55D-E
CPU: Intel Core i5 750 2.66GHz Socket LGA1156
RAM :
4GB G.Skill ECO Series CL7 DDR3 Dual Channel kit (2x 2GB modules)
Case: CoolerMaster Storm Scout
PSU: Coolermaster GX 550W PSU - 6x SATA 2x PCI-E 80plus Certified
HDD: Samsung HD103SJ Spinpoint F3 1TB Hard Drive SATAII 7200rpm 32MB Cache
GPU: XFX HD 5770 850MHz 1GB DDR5 HDMI Dual DVI Display Port PCI-E Graphics Card
OEM: Windows 7 Professional 64-bit
Total: 697.42 approx $
1,121.96 (canadian)
Your views on this build?
Thanks for looking.
Old July 5, 2010, 07:49 AM
mjpd1983's Avatar
Sounds like a good rig i have a similar setup
i5 750 does very well with my 5870
You will enjoy it
Old July 5, 2010, 08:19 AM
fishingfanatic's Avatar
Smile New Builds
Good selection of components. I would get a Corsair psu over the CM though. Also, if/when possible consider getting a SSD for your OS.
Old July 5, 2010, 09:18 AM
Soultribunal's Avatar
I second the idea about a bit better quality PSU. That GX might 'look' good but in reality its a medicore PSU at best.
SOmething like a HX650, Silverstone Strider Plus 600/750W , Antec Earthwatts 650W ect... better for the longevity of everything you have there.
ST
www.realhardwarereviews.com
Old July 5, 2010, 09:20 AM
Scottyboy85's Avatar
Your build looks good. Good choice of graphics card. XFX has a terrific warranty.
I agree with fishingfanatic, corsair makes great PSU's.
Old July 5, 2010, 12:39 PM
you could squeeze a 5850 in there if you were to change mobo+cpu ;)
Old July 14, 2010, 11:43 AM
Buy it. But try and get a 5850 instead.
Old July 14, 2010, 02:27 PM
I also agree on trying for the the 5850, if possible. Also a better PS, corsair makes some excellent ones. Either way your spec is still a good one and will make an excellent PC
Good Luck
Cheers; Snarl
Another Guy From Canada
Complete and Final build Crysisfan11 New Builds 6 May 23, 2009 11:05 PM
New build, need final opinions Mavvens New Builds 21 March 17, 2009 05:39 PM
i7 Final Build ev0styLe New Builds 15 January 18, 2009 08:40 AM
Final Build, With Some Changes.... mlauzon New Builds 23 December 10, 2008 01:04 PM
final build xghostz New Builds 8 October 19, 2008 05:41 AM
