Old June 21, 2010, 07:43 PM
Default ITX WHS Build recommendations - 1156/i3/6HD's/Small Case
Hey guys:
I am thinking of building a new WHS that is ITX based and need some suggestions: My current one is mATX 775 and is in an Antec P183 that i am not using to its max ability. too much space for me.
1) The WHS must be relatively quiet, power efficient, relatively small case that can hold at least 6 hd's @ 2TB each, etc
Was thinking:
Zotac H55/intel h55 itx board with i3-530 (i assume that i can expand via esata to nas storage if i have to later on and that i can undervolt if i have to)
2 gb ram
PSU ??
Case? li lian q08
pcie slot to be used for sata card?
WHS is used to back up 3 pc's, serve up HD movies (Blu ray rips @22GB), serve up 3 small personal websites with very low traffic.
Any help is greatly appreciated
Budget - for everything but Harddrives should be $3-400?? give or take
last point would be that it should be capable of VAIL when released - which I see no reason why it wont.
Here is what i am planning to get:
Case: Li lian Q08
mobo: Intel DH57JG
cpu: Core i3 - 530
Ram: 2GB
psu: Cosair Corsair TX750W 750W ATX 12V 60A 24PIN ATX 140mm fan - existing item (will it work?)
pci-x: need a recommendation on a good 4 port sata card that also has a esata for a port multiplier or a good 4 port sata card where i can use 1 internal sata port to be an esata port that again has port multiplier.
HDD's: 7 WD 2TB drives (i plan to use the 5.25" slot for the 7th 3.5" HDD
let me know what you guys think.
S
Old June 21, 2010, 07:59 PM
Keltron 3030's Avatar
If interested, go grab an 1156 Xeon CPU. same as Core i3/i5 but with Hyperthreading
FFFFFFFUUUUUUUUUUUU-
Old June 21, 2010, 08:23 PM
can u send me a link to where i can buy it, whats the power rating
Old June 21, 2010, 08:40 PM
If you wanna pay the $100+ premium, than here you go : NCIX.com - Buy Intel Xeon X3440 Quad Core Processor LGA1156 2.53GHZ 8MB L3 Cache 95W Retail Box - BX80605X3440 In Canada.
Old June 21, 2010, 09:12 PM
i think i will stick with core i3
Old June 22, 2010, 04:23 AM
you may want to look at giga's offering as well, theres reports of monster clocks.
Old June 22, 2010, 08:51 AM
kingnubian's Avatar
The i3 will work great as realistically for a home server, raw unlimited cpu power isn't necessary & the i3 should be more than enough.
I would include these two itx H55 based motherboards to your list though, specially if you ever want to overclock that i3. I have listed them in order of preference.
Gigabyte H55N-USB3
NCIX.com - Buy Gigabyte H55N-USB3 Mini ITX LGA1156 H55 DDR3 1PCI-E16 DVI HDMI Sound GBLAN eSATA USB3.0 Motherboard - GA-H55N-USB3 In Canada.
ECS (Shown here bundled with an i3-530)
Buy the ECS P55H-CM w/ Ci3 530 CPU at TigerDirect.ca
Personally I would choose the Gigabyte board being that it has USB3, can overclock that i3 very nicely & is Ultra Durable 3 model. Problem is it only has 4 internal SATA ports, no RAID (Intel H55 lacks this), & 1 eSATA port. The Zotac has 6 internal SATA, WiFi but lacks USB3 & RAID (H55 Chipset Limitation).
Btw, the Intel DH57JG is based on the H57 chipset which supports RAID but only has 4 SATA ports & 1 eSATA. In addition to this overclocking options are very limited on this motherboard.
None of the boards listed have a pci slot for a possible sata RAID addon card btw.
The Lian Li case specs list that it will fit 6 hard drives & even if it does given it's size, good airflow would be a must. I really like this case though. Looking again at it's construction it seems that 6 hard drives would fit without much problem.
I like this build & have been considering a build like this for my everyday Linux workstation. As a server it will be great, just be wary of the itx & H55 based board limitations specially considering the number of hard drives you wish to use.
GOD Is Good
________________________________________
AMD Ryzen 1700 CPU
Asrock AB350 Pro 4 Motherboard
Corsair LPX 16GB (2x8GB) 3200Mhz
Adata SX8000 256GB NVME Drive
Crucial MX300 525GB M.2 Drive
EVGA GTX1080 FTW2
Corsair H105 AIO
Phanteks P400S Tempered Glass Edition
EVGA Supernova 650 G3
Old June 22, 2010, 05:58 PM
the intel board has a pci-e slot for a sata card\
usually intel nic is better than realtek which is i picked that board.
i don think i will be doing any overclocking....so the intel board based on pci-e,nic and esata for port multiplier.
S
Old June 23, 2010, 05:13 AM
Rison's Avatar
I keep recommending the Supermicro Atom X7SPA motherboard.
An Atom D510 is more than enough to run WHS (throw a 1GB or 2GB DDR2 SODIMM 200pin chip in - $40.)
Super Micro Computer, Inc. - Products | Motherboards | Pineview Boards | X7SPA-HF
The motherboard has dual Intel gigabit NICs, 6x SATA ports and Integrated IPMI. (iKVM) Even though WHS is headless, I have had to connect a monitor a few times when adding / removing drives (etc). It does have a passive heatsink, but most recommend throwing a fan near it (low rpm = low noise) and it's extremely low power and cost effective.
The MB/CPU combo is $225 on the egg, which is about the same than whatever else you were looking at ($100 MB + i3 CPU)
Newegg.ca - SUPERMICRO MBD-X7SPA-HF-O Mini ITX Intel Atom D510 processor Server Motherboard
I'll learn to manage my anger, when people learn to manage their stupid.
Old June 23, 2010, 07:43 AM
i should have mentioned this: WHS is used to back up 3 pc's, serve up HD movies (Blu ray rips @22GB), serve up 3 small personal websites with very low traffic.
i will take a look at that option - but seems limited as i cant replace cpu, but lots of features. i guess i am wondering about long term usage. also if i have to do any transcoding, it most likely wont be on the atom cpu...
Socket 1156 build recommendations Perineum New Builds 5 May 13, 2010 07:52 PM
ITX Case Recommendations? Dr_BenD_over Cases 10 February 23, 2010 11:48 AM
Silverstone SG05 ITX Case Mod Mnpctech Case Mods, Worklog & Gallery 39 October 26, 2009 02:52 PM
3 Builds - WHS Media Server and 2 Mini ITX HTPC's - Thoughts needed Shftup New Builds 14 March 21, 2009 07:35 AM
[WTB] Looking for a ITX form Case ddude27 Buy/Sell & Trade 0 January 19, 2009 09:49 PM
