Old June 12, 2010, 07:09 AM
Default New build please recommend $2200 dollars max
Hey guys, I'm new to the forums here and have been lurking for the past couple of days. I am currently looking to build a new pc for around $2200.00 CAD. If you guys could recommend any parts that would be great. I'm going to be reusing my ocz vertex ssd, my 1tb segate drive, dvd drive, monitors, kb and mouse and possibly my P182 SE case although this could change.
As for the video cards I was thinking about getting 2 gtx 470's or 1 5970. I'm open to anything but I do want an intel CPU.
Thanks.
Old June 12, 2010, 07:32 AM
fishingfanatic's Avatar
Smile New Builds
The 930 is a good cpu that is overclocker friendly. For a psu, look for a Corsair. With sli, you may need more than a 750, but with the 5970, the 750 is enough. For mobo, look at the ASus P6X58D-E. It has new usb 3 and sata 3. The premium has 2 rj 45 ports, but I never needed 2, and saved the 60-70 $ for something else, like beer!!! As for hsf, I've had the piezo electric for a while, so you may need someone else to help you. Keep in mind that I'm pretty new as well, but got help from these experts and did lots of research. One thing I would recommend is to keep an eye on the buy, sell, and trade section where you could get great deals on hardware and save even more.
Good luck and enjoy the build.
Old June 12, 2010, 07:56 AM
Great thanks for the advice!I was looking at the exact same mobo and CPU.
Anyone else have any other recommendation. I would like to get a couple of builds before I decide.
Old June 12, 2010, 08:27 AM
tmx220, welcome to HWC.
Check out this thread NOTICE - PC builders, when asking for input on YOUR projects Please Tell for info that you can provide to help the forum members make relavant suggestions.
Economical CPU heatsink: CoolerMaster Hyper 212+
Will you be using onboard audio or sound card
What are your listening requirements - songs, gaming, movies?
Do you require speakers (stereo or surround sound) and/or headphones?
Check out the HWC's Review Section for trustworthy reviews on components.
+1 fishingfanatic's post.
NCIX.com will price match against a reasonable competitor.
Hope this helps,
Peter
Old June 12, 2010, 09:34 AM
Thanks for the welcome Pete. I apologize for not finding that template to be used for help. I will be using onboard sound.
1. What YOUR PC will be used for.
High End Gaming, Rendering 3dsmax, Autocad, Revit.
2. What YOUR budget is.
$2200.00
Canada
4. IF YOU have a brand preference.
Intel
Vertex ssd, seagate 1tb, monitor/mouse/keyboard.
Yes I have.
Will be overclocking.
Will be building it in two weeks.
9. What resolution do you use?
1920x1080.
Old June 12, 2010, 12:01 PM
Mobo: ASUS P6X58D-E
NCIX.com - Buy ASUS P6X58D-E X58 ATX LGA1366 3PCI-E16 PCI-E1 2PCI CrossFire SLI USB3.0 SATA 6GB/S Motherboard - P6X58D-E In Canada. 265.62
RAM: OCZ Gold 8-8-8-24 1600
NCIX.com - Buy OCZ Gold OCZ3G1600LV6GK 6GB DDR3 3X2GB DDR3-1600 PC3-12800 CL 8-8-8-24 Triple Channel Memory Kit - OCZ3G1600LV6GK In Canada. 179.99/164.99 MIR
GPU: 2 x EVGA 470 Superclocked (Lifetime Warranty + Percision OC Tool)
NCIX.com - Buy EVGA GeForce GTX 470 Superclocked 625MHZ Fermi 1280MB 3.4GHZ GDDR5 2XDVI MINI-HDMI PCI-E Video Card - 012-P3-1472-AR In Canada. 779.89
CPU: i7 930
NCIX.com - Buy Intel Core i7 930 Quad Core Processor LGA1366 2.8GHZ 8MB L3 Cache 130W 45NM Retail Box - BX80601930 In Canada. 309.99
PSU: Corsair TX950
NCIX.com - Buy Corsair TX950W 950W CMPSU-950TX 12V 78A 24PIN ATX Active PFC 140M Fan Power Supply - CMPSU-950TX In Canada.
189.99
Case: HAF 932
NCIX.com - Buy Cooler Master Haf 932 Full Tower Black EATX Case 6X5.25 1X3.5 5X3.5INT No PSU USB eSATA 1394 Audio - RC-932-KKN1 In Canada. 149.99
total without shipping etc 1875.74.
Enough room to add
Corsair H50: NCIX.com - Buy Corsair Cooling Hydro Series H50 High Performance CPU Cooler System LGA775 LGA1366 LGA1156 AM2 AM3 - CWCH50-1 In Canada. 89.99
and 2 of these NCIX.com - Buy Scythe Slip Stream Kaze Jyuni 120MM Fan 1900RPM 110.3CFM 37DBA - SY1225SL12SH In Canada. for a push/pull on the radiator. 15.74
End total = 1981.20 (w/o shipping/tax)
Old June 12, 2010, 02:30 PM
if you have to have intel...hmm...the 750 or even xeon 3440 and a nice giga board, maybe even evga around 150 buckers will do you good.
Old June 12, 2010, 05:16 PM
Hey guys thanks for the great advice. I decided on a pc which I have ordered from Direct Canada. This is my first time ordering from them. I'm slightly worried after reading some of the reviews about them. Do they ship fast enough and are good with customer service?
Old June 12, 2010, 07:48 PM
ok..what did you order? dc is ok, a bit sluggish with the answers and such.
Old June 13, 2010, 07:02 AM
Intel Core I7 930 Quad Core Processor LGA1366 2.8GHZ 8MB L3 Cache 130W 45NM Oem
1 Yes $308.67 $308.67
ASUS Rampage III Extreme ATX LGA1366 X58 DDR3 4PCI-E16 PCI-E4 CrossFire SLI SATA3 USB3.0 Motherboard
1 Yes $411.48 $411.48
Coolit Systems Eco CPU Water Cooling System AUTO-REGULATED & Maintenance Free LGA1366/1156/775/AM3
1 Yes $66.74 $66.74
Corsair HX1000W CMPSU-1000HX 1000W ATX 20/24PIN ATX 80A 12V Afc Modular Power Supply W/ 140MM Fan
1 Yes $241.50 $241.50
Sapphire Radeon HD5970 725MHZ 2GB 4.0GHZ DDR5 PCIe 2XDVI 1XMINI DisplayPort CrossFireX Video Card
Scythe Slip Stream Kaze Jyuni 120MM Fan 1900RPM 110.3CFM 37DBA - 2 of them.
Waiting on some suggestions on ram for the motherboard.
What do you guys think??
Mass effect 10 dollars on steam BrianHanna Gaming 3 November 7, 2009 05:52 PM
looking to build a budget HTPC. recommend me a case redman Cases 2 July 26, 2009 08:49 AM
Best GPS Automotive unit for 300-400 dollars Dashock Off Topic 9 September 7, 2008 08:04 PM
I have a BOXX dual AMP 2200+ system that i believe is overheating maytagazn Troubleshooting 3 April 11, 2007 08:11 PM
