Nice work man... Glad to see it worked out for you. Enjoy your new monitor.
Sorry for the delay... I had a build issue with my new case regarding the top mounted fans and my Lian Li PCI fan controller. Fan wires for top mounted fans simply weren't long enough. I have 3 top mounted fans I needed to connect, but only 2 extensions... Ended up having to break out my favorite modding tool. My good old Dremel. Best multipurpose tool I've ever bought. Damn I love this thing. Drilled a hole on the back of my Cosmos S near the top just to the bottom right of the water cooling tube holes. Cut the PCI plate with the cutting disc (and dulled the edges with the grinding stone bit) so I could mount it inside the case and screwed it in place. Now I only needed one extension for the top fan nearest the front. The only annoying part of the mod was I had to remove a little of the acoustic sound dampening material I just installed a couple days ago in order to fit the controller board properly. Tested it with a crap system I use for testing certain components and was very happy to see I didn't accidentally break it in the process of installing the mod. That's just put me in a real good mood. That's been bugging me for days... I'm so glad it worked.
BTW... I'll probably be going down in the next couple hours to start moving my components from my old case to my new. Once I start I'll be down for a while. For the meantime... Eat, smoke, drink and tie up remaining loose ends before I start.
