Hi, will that card fit in that case? I ask because I have 3 different figures for the maximum graphic card size for this case. The
release info tended to say 290mm,
this picture suggests that the top pcie slot can hold up to 430mm (with the end poking into the internal 5.25" bays slightly - if that is possible) and the
Lian-Li 2010 catalogue (23mb download) says maximum possible graphic card is 310mm. :\
So is it:
a) 290mm,
b) 430mm, or
c) 310mm?
(as I understand it, the reference 5970 is ~340mm.)
