  #21 (permalink)
Old June 1, 2010, 08:43 PM
Keltron 3030's Avatar
Originally Posted by Jaak View Post
I did not mean to snub you and I defiantly did not ignore your build. I have done a lot of reading and found that the Phenom II X4 and X6 CPUs are limited to DDR3-1333 RAM. Faster ram will not preform any better (please correct if wrong). Why did you choose only 4Gigs of ram for the build you posted for me?
I hate to say but you are dead WRONG here!
I am running a Phenom II X4 955 with DDR2 RAM.
It's not the CPU which limits memory, it's the chipset of the board. The 800-series only runs DDR3 RAM.
I do believe you have more reading to catch up on........
FFFFFFFUUUUUUUUUUUU-
  #22 (permalink)
Old June 1, 2010, 09:14 PM
So I made another updated list.
MSI 890FXA-GD70 <--- Does not look as nice as the Crossfire IV Formula but MSI tested to work with my ram plan
G.SKILL Ripjaws Series 8GB (2 x 4GB) 240-Pin DDR3 SDRAM DDR3 1333 (PC3 10666) F3-10666CL9D-8GBRL <--- Said ram to be upgraded to one more of this kit at a later date (if I really really still want 16Gigs)
AMD - Phenom™ II X6 1090T Six-Core Black Edition <--- Cuffed for considering going with the X4 965
eVGA - GeForce GTX 480 <--- Heat? Heat! I don't care about heat. I'm getting a HAF 932!
Corsair - HX 850W Power Supply <--- Future proofing power (probably could go with the 750, but this one was only $20 more)
Intel X25-M Mainstream 80Gig <--- What's the point of having a fast computer with a slow drive. Intel also does not make a bad product, but the price is a little rough.
Cooler Master Hyper 212 Plus CPU Cooler <--- Like I said, who cares about heat.
Cooler Master - HAF 932 <--- I had a full size case back in the 486 days and loved it. I can't wait to see this thing in person. The reviews make it look like Mount Olympus.
All this does go a little over my $2000CND budget, but I'll make it work.
Any advice/opinions?
I'm still a little iffy about the SSD, is there anything comparable (or even better) at a lower price?
  #23 (permalink)
Old June 1, 2010, 09:27 PM
FreeKnight's Avatar
If you want to go with a 470 for your video card (better bet than the 480 IMO), NCIX now has (or did a few days ago) EVGA's new Superclocked+ 470. It runs cooler and quieter from what I've read so that helps cut down on one of the biggest complaints about fermi (power consumption is still.... eeeeeep)
  #24 (permalink)
Old June 1, 2010, 10:47 PM
Can you explain how the 470 series is better then the 480 series?
nVidia’s VP for CUDA and PhysX moves to AMD? burebista Rumor Mill 14 June 9, 2010 08:47 AM
DX11 Questions from NVidia answered by AMD Babrbarossa Video Cards 4 September 24, 2009 01:12 PM
What is equal to Nvidia 8600GTS on AMD? CactusJoe New Builds 13 February 2, 2009 12:58 PM
NVIDIA's GDDR5 Stance Differs from AMD's Hardware Canucks Press Releases & Tech News 3 May 23, 2008 01:20 PM
Dirty Pool: Intel vs NVidia- AMD, here I come Babrbarossa CPU's and Motherboards 6 November 18, 2007 05:02 PM
