<~----> Updated!!!Planned Build NOW FINALIZED - Page 2 - Hardware Canucks
Old May 25, 2010, 07:13 PM
0o0 0o0 is offline
hmm you want that side panel fan eh? rings a bell for me... this is what I was debating with my hyper 212+ purchase, the N520, which I later found out is a lot better than the hyper 212+ in terms of build quality. It's not very popular though, because most people just like 120mm fans because it's 'bigger'.
9800gt is still very good, keep it until you can afford an upgrade. It's still a very respectable card among 'regular' folks out there, it's worth about $50-70 now and it's gonna stay like that for quite some time. Incase you want to upgrade, people do still buy that card used simply because it's good for use with CUDA :) Everything else looks good so far... if we see any good psu deals tomorrow night, we'll let you know here.
edit: on second thought, I'm not entirely sure that the side fan would fit with the n520, double check...
Old May 25, 2010, 07:20 PM
Yeah i'll check out the n520, and the 9800 is borrowed from my friend until i can save up for a 5850, or maybe something better, if you have any other gpu in mind? But then again this is basically just the start of getting my comp to function, i'll be doing some upgrades later when i have more money. Lets just hope they have good psu deals tmr
Old May 25, 2010, 07:33 PM
0o0 0o0 is offline
I'll keep an eye out for you in BST section. I recently grabbed a gtx260 for $130 shipping, it was just like new, to give you an idea of a cost for a gtx260 if you're interested in that. I've seen another one (identical model) for for $120, that was at redflagdeals (as you can tell from my signature, I hate dealing with those animals). I would personally recommend a gtx470 to you whole-heartedly, unless you want to wait for the little brother (possibly gtx465 or gtx460?), which should be cheaper. Btw, the review by xbit labs for the gtx465 looks fake/biased to me, I wouldn't trust it. If you were to buy new, definitely either 5850 or gtx470... the 470 should be around 320-340 and 5850 should be 250-280 depending on brands, and those would be very good prices.
Old May 25, 2010, 07:42 PM
steers's Avatar
Might I also suggest the Seasonic X650. Fully modular, single rail, 80PLUS Gold, price matches to less than $150.
Just puttin it out there
Balthasar - Loop: EK Multi 150 > MCP655 w/X-Top2 > Feser X-Changer 360 w/3x Panaflo 68cfm (push) > Heatkiller 3.0 > EK-FC275 > EK-FB Classified
Caspar - 2x Xeon E5504 | SuperMicro X8DAi | 12GB DDR3 | Radeon HD4850 | CM ATCS840
Melchior - Rev. A MacBook Pro | 2.0GHz Core Duo | 2GB DDR2 | Radeon X1600
Bob - Core i3 530 | Gigabyte H55N-USB3 | 4GB DDR3 | Corsair H50 w/ TFC Triebwerk | Silverstone SG06
Old May 25, 2010, 07:43 PM
i was on ncix searching the 5850 and the prices there were like 320+. i never saw one under 300. So between the 5850 and gtx 470, which one is better in terms for gaming, movies and etc. And the gtx 470 is 370 at the very least. since i got time to save for a gpu, i can get one of the more higher end ones but i believe the 5850 is more than enough for hon, cs1.6, and d3 and whatever comes out next
Old May 25, 2010, 07:53 PM
0o0 0o0 is offline
I know what cs1.6 is... it's very old and any computer can run it. I don't know what the other 2 are. With 5850 and 470's, we're talking about metro 2033, BC2 and Crysis here. CS1.6 takes next to no hardware to run, compared with the 470. Just wait for a sale, the regular ncix prices are ridonculous and you'd have to be stupid or desperate to buy them at regular price
Old May 25, 2010, 07:59 PM
LOL yeah i'll just wait till then, maybe get a better card for a even lower price. all i gotta worry about is getting everything else at a lower price. i think i'll just price match i5 750 at 200
Old May 25, 2010, 09:17 PM
Kayen's Avatar
Hey, for HoN and Diablo 3 , evne an HD3850 will run those at MAX settings on a 24" monitor.
So don't shoot for that high .
Oh and ask one more stupid question, and i will personally kick your ass tonight .
  #19 (permalink)
Old May 26, 2010, 06:51 PM
0o0 0o0 is offline
NCIX.com - Buy Gigabyte GeForce GTX 470 Fermi 607MHZ 1280MB 3348MHZ GDDR5 PCI-E 2XDVI MINI-HDMI Video Card - GV-N470D5-13I-B In Canada.
NCIX.com - Buy Antec Truepower New 650W Modular Power Supply ATX12V V2.3 Active PFC 80 Plus SLI Ready 120MM PWM Fan - TP-650 In Canada.
pretty good deals. I haven't had much experience with Antec, but this psu looks solid. Do some research before buying :)
  #20 (permalink)
Old May 26, 2010, 07:06 PM
jcmaz's Avatar
Actually most of the recent onboard graphics are able to run CS1.6 quite well :)
You my friend, need some new games.
-Plato
Need input on a planned ITX build biff HTPC Systems & Software 2 May 21, 2010 10:21 AM
Core 2 Quad Upgrade planned for 6 months to 1 year down the road... grifter11 New Builds 22 August 12, 2009 07:17 PM
Nvidia 9800GTX+ planned for 229$ Jackquelegs Video Cards 4 June 19, 2008 02:57 PM
Heres my planned build, does everything look ok. shanty140 New Builds 28 June 2, 2008 01:25 PM
Planned Budget System - Appreciate Opinions misterlarry CPU's and Motherboards 28 January 16, 2008 06:55 PM
