Old May 20, 2010, 07:49 PM
bovine.baron's Avatar
Alright, thanks. Can you link to the mobo+cpu you mean, please?
Old May 20, 2010, 07:52 PM
rapmaster's Avatar
You can go with an Athlon 630 for 100$.
AMD CPU ADX630WFGIBOX ATHLON II X4 630 95W AM3 2MB 2800MHZ RETAIL
if not an Athlon 250 for 64$
AMD Athlon II X2 250 / 3 GHz - Socket AM3 - L2 2 MB ( 2 x 1 MB )
Old May 20, 2010, 08:02 PM
http://ncix.com/products/?sku=111120...cture=Gigabyte
NCIX.com - Buy AMD Athlon II X2 250 Dual Core Processor Socket AM3 3.0GHZ 2MB Cache 60W Retail Box - ADX250OCGQBOX In Canada.
looks like the 240 is not in stock. hell you can go with a cheaper board that doesnt crossfire but for 10 bucks, another pci-e slot is welcome
Old May 20, 2010, 08:42 PM
Thanks a ton, guys! I went with the 250 though I'm not using the mobo dangtx recommended because it's showing up in my cart as special order. Pricematched, this MSI mobo is about the same price, looks good to me, and has positive reviews.
Old May 20, 2010, 08:50 PM
jcmaz's Avatar
The MSI mobo you linked isn't really futureproof in the sense that the supported ram speed are extremely low.
-Plato
Old May 20, 2010, 08:57 PM
well, close enough lol.
Old May 20, 2010, 09:05 PM
Oh God, I totally missed that! Well, that's what you guys are for Okay then, take 3: Gigabyte GA-770TA-UD3
Old May 20, 2010, 09:10 PM
jcmaz's Avatar
HEHE, i looked at that specific MSI mobo you were talking about. From the title, it looks great, but the product is meh...
I second the Gigabyte board.
-Plato
  #19 (permalink)
Old May 28, 2010, 06:02 PM
Cz3ch's Avatar
Same and you can PM it to 82$ AMIR
  #20 (permalink)
Old May 28, 2010, 07:05 PM
0o0 0o0 is offline
Only thing I would change is the amd to a intel i3 or i5. Stick with the gt240 by the way, it's very good. Intel is just much more snappier than amd in general. Intel chipsets are also of much higher quality.
Budget Build - College Student!!! AstonM New Builds 3 May 2, 2010 06:38 AM
1000$ build belinik New Builds 17 December 10, 2009 09:36 PM
New general use build manblogsdog New Builds 9 September 6, 2009 04:14 AM
$1000 laptop for student? GregH Mobile Computing 16 April 3, 2009 08:30 AM
Build me a quite PC for $1000 min New Builds 23 March 28, 2009 12:45 PM
