Old May 13, 2010, 04:07 PM
Question My build V2
http://www.hardwarecanucks.com/forum...out-build.html
I have taken in some suggestions and such and edited my build. I got my hands on some extra cash so I was able to switcharoo for a 5780. Also could you suggest a better case at around 150 dollars I don't know.
Also is this power supply any good? NCIX.com - Buy OCZ ModXStream Pro 700W ATX 20/24PIN SLI Ready Modular Cables 135mm Fan 80PLUS Power Supply - OCZ700MXSP In Canada.
This is my first computer, I consider it a goal. So any suggestion to make it better are welcome.
God Save the Poutine
Old May 13, 2010, 04:42 PM
fishingfanatic's Avatar
Smile New Builds
I would change my psu to Corsair. Those supplies you're looking at are suspect. You can't go wrong with Corsair. I recently looked for a 750w and found one for sale for about $100.
Edit: I would consider the HAF 922 if you want mid size, or the HAF 932 for full size. CoolerMaster makes good cases. I would consider getting the x6 cpu which is vitually the same price, and it future proofs you with 6 cores.
Edit 2: If I could get 8 gigs of ram, that works so much better. Someone, myself included, may have some good used stuff for sale at a reasonable price. PM me if you're interested in my memory.
Old May 13, 2010, 04:51 PM
I agree with the full, but the half i would go with the cooler master storm sniper black edition comes with allot of small things that make it great!, fan controldust filters, black interior...
New Build- Corsair 800D --> My cleanest build ever. Watercooled btdvox Case Mods, Worklog & Gallery 28 May 11, 2010 01:07 PM
Windows 7 Build 7000 VS Windows XP SP3 Build 2600 Benchmarks Veritas Overclocking, Tweaking and Benchmarking 3 March 3, 2009 02:48 PM
