-   -   need advice for a VERY inexpensive quad core (http://www.hardwarecanucks.com/forum/new-builds/32041-need-advice-very-inexpensive-quad-core.html)
hfxmike May 12, 2010 02:59 PM
I have everything except mobo, cpu and ram.
Will be used for video transcoding and the usual multi-tasking.
(I have a decent case, 8800 GT OC, 2x500gb hds + 1TB hd, 550W PSU)
$400 max. Was thinking of going with the AMD 620/630 quad cpu.
Not sure about the mobo, but here are the requirements for me:
- ATX
- 4 ram slots
- 5 SATA II ports
- 1 PCI-e slot
- 3 PCI slots
- onboard vid
- IDE controller
ram - DDR2 800 probably. 4 gigs
I'll be running 2 monitors initially. Want the onboard so I can add a third with no hassle.
I can get a prebuilt, new quad on ebay for $400 total, BUT
- I hate mATX
- need more PCI slots
- need more SATA ports.
- want 4 ram slots
No preference wrt Intel/AMD, but pretty sure that I want an Asus mobo.
all advice welcome
thanks
mike
_dangtx_ May 12, 2010 03:19 PM
x4 620/630 and giga 785g for 200 +-
sswilson May 12, 2010 03:39 PM
Will you be overclocking?
hfxmike May 12, 2010 04:14 PM
possibly, but only by a slight amount.
is there a cpu/mobo in my price range that would give me a stable overclock?
hfxmike May 12, 2010 04:49 PM
just checked newegg.ca and the 620 and 630 are the same price!
not sure about the giga 785g Newegg.ca - GIGABYTE GA-MA785GM-US2H AM3/AM2+/AM2 AMD 785G HDMI Micro ATX AMD Motherboard
i took a look at it and thought that my video card would block 1 or 2 sata ports, then read the customer reviews.
_dangtx_ May 12, 2010 04:52 PM
or go for the top of the line(at reasonable price of course) 790 ud4P
LacrosseTown May 12, 2010 04:55 PM
maybe this mobo:GIGABYTE 890GPA-UD3H 890GX (140$can)
with this cpu:AMD Athlon II X4 640 (110$can)
and this cpu cooler with that extra cash: COOLER MASTER Hyper 212(30$can)
for small oc'ing this setup will do very well!
and should still give you enough cash to spend on good ram!:thumb:
if it where me i would go for a gig mobo for middle price!
you get all those slots you wanted and a few more extra and on board vid!
jonnyrockets May 19, 2010 10:22 PM
CPU - AMD X3 720. 6mb cache.
Performance on Games and benches only a little below an x4 940 and 920, actually beats them on fear and crysis low res . . . The jump from 2 to 3 cores is noticable . . . 3 to 4 - negligable unless you're using pograms such as CAD / 3d etc.
Also - if you're lucky - you can unlock the 4th core on the 720. Either way - it's an awesome overclocker. Some are pushing 3.5ghz out of it.
price - under 100 canadian. it's an OEM from newegg - so buy a cooler and you're rockin.
MOBO - me personally - I don't like multi card setups - so one PCI-E x16 slot is good enough - gigabyte something or other. Everyone has their preferences. Asus, gigabyte . . . good boards - me - asus's have bitten me in the ass. Giabytes haven't - but I have friends the other way around.
Newegg.ca - GIGABYTE GA-770TA-UD3 AM3 AMD 770 SATA 6Gb/s USB 3.0 ATX AMD Motherboard
Newegg.ca - AMD Phenom II X3 720 Black Edition Heka 2.8GHz 3 x 512KB L2 Cache 6MB L3 Cache Socket AM3 95W Triple-Core Processor - Processors - Desktops
Newegg.ca - G.SKILL Ripjaws Series 4GB (2 x 2GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800) Desktop Memory Model F3-12800CL9D-4GBRL
300 bucks - Rock and roll my friend.
sell the 8800 for 40 bucks - buy a 5770 for 140 - and you've got your budget there - plus the 5770 will kick the shit outta the 8800.
jonnyrockets May 19, 2010 10:30 PM
Crap - noticed your uses for the machine - and yeah quad core - anyway - you're at around 200 with mobo and rammage - so 200 for cpu brings you into the nice black edition quads from AMD.
hfxmike May 27, 2010 09:41 AM
thanks for all the advice - i didn't get notification of the replies.
i decided to go with this:
Asus M4A79XTD-EVO AM3 Motherboard - $138.00
AMD 635 Quad 2.9Ghz - $118.00
Kingston 2x2GB DDR3-1333Mhz - $66 x 2 = $132
Subtotal = $388
Tax = $50.44
Total = $438.44
decided to buy from a shop down the street from me in case there are any issues. worth the extra bucks.
www.greenlyph.com
