Old May 11, 2010, 08:10 AM
Default Leo the dragonII build
yeah i know the title is a little humerus, its a leo system with this proc
AMD Phenom II X4 965 Black Edition
because i heard from around the forums that in gaming you only use four of the 6 cores in the hexacore so i said may as well not pay the extra 100 for cores i won't be using, any opinions suggestions for that idea?
Old May 11, 2010, 08:16 AM
bojangles's Avatar
The 965 is an amazing processor from AMD. Gaming will be solid on that chip. Now, just browse through the AM3 motherboard reviews here and find a board with the features you like :). Easy peasy!
If you want you could put that $100 from the 6-core CPU to an SSD and notice a great improvement in speeds...:P
Old May 11, 2010, 08:23 AM
yeah that was my plan! because im going to use the crosshair IV formula because of amasing overclockability and then this
hard drive:Western Digital Caviar Black WD5001AALS 500GB
this ssd:Kingston SSDNow V Series
Old May 11, 2010, 08:27 AM
bojangles's Avatar
If you can the 1TB Black version gives a bit of a speed boost as well.
I'm sure you're fine with finding the right RAM and such. What GPU are you going to match that computer with? 5850?
Old May 11, 2010, 08:33 AM
definitely, almost as if you read my mind...!!
ASUS EAH5850 DirectCU TOP
crazy overclocking capabilities, it was made for ocing!
Old May 11, 2010, 08:35 AM
bojangles's Avatar
You're good to go! Choose a case to your liking and a PSU and you're all set. Corsairs are remarkable. Modular is the best in my opinion (for time and cable management). Don't forget DVD drive, cooler, etc.
But yeah you're gonna love that setup .
Enjoy!
Old May 11, 2010, 08:40 AM
Enjoy!
read my mind again :/ frick, its getting freaky
yeah the psu:CORSAIR HX Series CMPSU-850HX 850W
case: COOLER MASTER Storm Sniper black edition
Old May 11, 2010, 09:28 AM
fishingfanatic's Avatar
Smile Leo the Dragon II
This sounds like a pretty awesome setup. Good luck with the build!
Old May 11, 2010, 10:11 AM
bojangles's Avatar
We would love it if you posted a build log or some pictures of your computer after!
Old May 11, 2010, 11:04 AM
definitely!!
New Build- Corsair 800D --> My cleanest build ever. Watercooled btdvox Case Mods, Worklog & Gallery 28 May 11, 2010 01:07 PM
Windows 7 Build 7000 VS Windows XP SP3 Build 2600 Benchmarks Veritas Overclocking, Tweaking and Benchmarking 3 March 3, 2009 02:48 PM
