Old May 8, 2010, 08:40 PM
Default Building a lew system for gaming
first all do a brief summary of me because this is my first post, i've been reading over your reviews and there great! especially the video ones!! i come from montreal, play sc,sc2,bfbd2,codmd2, tf2 ect...
well enough about me here are the specs for the rig all be ordering soon....
cd reader: SAMSUNG 24X DVD
cpu cooler:Noctua NH-D14
case:cooler master storm sniper black edition
mobo: ASUS Crosshair IV Formula
vid card: asus EAH5850 DirectCU TOP
Power supply:CORSAIR CMPSU-850HX 850W(modular)
proc: AMD Phenom II X6 1090T Black Edition
memory: OCZ AMD Black Edition 4GB
hd:WD VelociRaptor WD6000HLHX 600GB 10000 RPM
keyboard:Logitech G15
monitor:ASUS VH236H Black 23"
mouse: GM-M8000X
anyone have any sugestions or comments?
Old May 8, 2010, 08:48 PM
Noctua NH-D14 is a great cooler but if you don't plan on crazy overclocks go with a Zalman Flex or Hyper 212+. Great pick for your power supply. As for your hard drive not sure if I would go that route. And many people have had "problems" with OSZ ram. G.Skill is great and not expensive.
Old May 8, 2010, 08:56 PM
yeah, the hd and memory, are temp until i will be able to put a ssd and the when the new G.skill flare will replace them eventually... but clearance might be an issue... danm those huge unneeded heat sinks but if the ocz's work well no need to worry about clearance
and the with the cpu im planning to oc it to 4ghz...
If you do go with the Noctua NH-D14 be careful which ram you choose. You could have height clearance issues.
"What is the colour when black is burnt ?" - Neil Young
Old May 9, 2010, 09:33 AM
This is just a suggestion but the hd that you have is crazy over kill... don't get me wrong a VelociRaptor is sweet to have but the 600gb one is like $320, from my understanding you put your OS and some other minor stuff on it (games)and thats it. If you picked up the 150gb veloci and then bought a 500gb wd to toss your movies and mp3's and all that other junk on, it would leave you with enough cash to maybe upgrade that 5850 to a 5870 or to a gtx 470. just a thought..
Building a new I7 system billionaireclub New Builds 10 February 21, 2010 06:26 AM
Building a budget system around a 4850x2 Vethrik New Builds 14 March 5, 2009 05:49 AM
Building a new system $2800 budget probationer New Builds 51 November 3, 2008 02:35 PM
Building a gaming system around 1200$ Muad'Dib_53 New Builds 4 August 9, 2008 04:30 PM
Building a Dual Socket System Paul Rogers CPU's and Motherboards 8 February 6, 2008 05:01 PM
