Old May 6, 2010, 11:10 PM
Default Need help building budget gaming rig!
Gaming, web surfing, watching movies
-$800-1100
-Vancouver, Canada Ncix
4. IF YOU have a brand preference. That means, are you an Intel-Fanboy, AMD-Fanboy, ATI-Fanboy,
nVidia-Fanboy, Seagate-Fanboy, WD-Fanboy, etc, etc, etc, you get the picture.
-no perference in brands
- i have a 24 inch samsung monitor, mouse, keyboard, OS(windows 7)
- no i do not plan on overclocking(Don't know much about it)
hopefully in 2-3 weeeks
9. What resolution do you use?
1920-1080
Old May 6, 2010, 11:22 PM
well start off with a 5870 or 5850, corsair psu(600 for one card)
cpu and mobo...hmm..save your casho and go amd regor and a giga board of your choice.
ram? if you have ddr2 use it else you can go to ddr3
Old May 6, 2010, 11:30 PM
CPU/Mobo: i5-750 and Asus P7P55D-E Pro $375.
RAM/GPU: G.Skill Ripjaws 2x2 GB 1600 mhz CAS Latency 7 and HD 5870
HDD: Seagate 7200.12 1 TB
PSU: Corsair 750W
Case: HAF 922
opinions please?
Old May 7, 2010, 09:02 AM
nice choice!
btw, the xfx 5870 is on sale for a sweet price in ncix!!!
and change that seagate to Wd black... i know that the .12 series is better than .11 .. but for 1TB of data, i wouldnt risk it.
and always PM ncix with the best price... use shopbot.ca AND pricecanada.com to check out lowest price! good luck man!!!
EDIT:
Btw, u sure u wont be getting an aftermarket heatsink? lol 20bucks extra wouldnt hurt.. but ok, since you stated that you wont be overclockin it....
Old May 7, 2010, 09:45 AM
Full Speed's Avatar
It's sold out now actually. The 5850 on sale is sold out too.
But yeah lilevilboi, that looks like an awesome build. Pretty simular to one I have in the mail, only I went i7 860 and 5850.
Old May 7, 2010, 10:22 AM
Thanks for input guys! btw would it be cheaper if i went with an amd build?
Old May 7, 2010, 10:41 AM
CPU/HSF: X4 955 and Coolermaster Hyper 212
Mobo: Gigabyte GA-770TA-UD3
HDD: Seagate 7200.12 500 GB
PSU: Antec Earthwatts 650W
Case: HAF 922
Optical: Cheap SATA DVD burner
opinions please and thank you!
$500 Budget Gaming Rig PC_Commando New Builds 26 January 18, 2010 04:44 PM
Need Help Building a Gaming Rig for $800 mr_syn New Builds 13 January 10, 2010 05:47 PM
Budget gaming rig <900$ 2ez4u New Builds 13 June 18, 2009 12:53 AM
New core i7 gaming budget rig oczdude8 New Builds 18 April 27, 2009 09:17 PM
New to PC gaming. Requesting help building a rig. Zippoh New Builds 19 November 2, 2008 10:35 AM
