Old May 2, 2010, 10:11 AM
Default Motherboard screwed too tight?
Hi guys, just got a new case and I'm putting an old motherboard in it. I put my motherboard in and tried to start it up, but it wouldn't power up, went through a lot of troubleshooting then finally realized that if I don't screw the motherboard down on the case, it works perfectly fine.
I then preceeded to screw the mobo in, but not too tightly and it worked, any tighter and it doesn't start again. The dilemma is that the screws I have aren't very long, they're the standard size ones, so maybe its causing the mobo to flex?
Anyone ever experience this before? Does anyone know the reason for this? is something on the case causing a short on the mobo?
New on HWC but lots of feedback on RFD (89-0-0)
XBMC Rig (1900PPD): AMD Athlon II X2 240 @ 3.2ghz | Gigabyte GA-MA78LM-S2H | G.Skill 2GB DDR2 800 | WD Caviar Blue 500GB | Antec NSK1300 SFF Case
Folding Rig: (1700+4500PPD) Intel Core 2 Duo E6600 | Gigabyte GA-P35-DS3L | OCZ Special Ops 2GB DDR2 800 | EVGA 9800GT | G.Skill Falcon 64GB SSD | Samsung Spinpoint 1TB | Seagate Momentus 1TB | Generic ATX 430W Case
Old May 2, 2010, 10:23 AM
gingerbee's Avatar
for me when a board flex causes it not to work it gets rma right away, if that's the problem are you sure it's not just shorting out somewhere on said case just a thought
Old May 2, 2010, 10:25 AM
Make sure that you only use the required number of mb standoffs. A standoff in the wrong place can cause grounding problems and short circuiting resulting in motherbord damage or death. Also make sure that the I/O shield tabs don't wind up placing themselves in usb ports, ethernet ports and such on the rear of the motherboard. You could also try screwing down the motherboard without the I/O shield and see what happens.
Old May 2, 2010, 10:35 AM
put on some thick gloves. fire it up, gently pick it up and see if it shuts down etc. if yes...rma or changing mobo, as already sugested
Old May 2, 2010, 11:36 AM
How do you know which ones are the required standoffs? the mobo functions perfectly fine with 2 screws in it, I'm just afraid of it not holding or having too much pressure on one spot.
Old May 2, 2010, 11:55 AM
The motherboard only has a certain amount of mounting holes in certain positions. You need to make sure that you only have standoffs installed in the case that correspond to those positions. If you have an extra standoff located somewhere on the board, it could be contacting some electrical connections on the underside which can cause problems.
Old May 2, 2010, 12:02 PM
Problem solved, as always, totally appreciate it guys!
Old May 2, 2010, 12:23 PM
Quite a few people have made the same mistake including myself. I'm glad you didn't fry your board.
Old May 2, 2010, 01:43 PM
fishingfanatic's Avatar
Smile Motherboard too tight?
So what was the problem? Was it extra posts?
newb tight budget build Weak15Ten New Builds 4 August 5, 2009 11:04 AM
I think my motherboard is screwed how can I tell if that what is my problem? Shadowmeph CPU's and Motherboards 5 July 20, 2009 07:15 AM
How tight is tight? Beermaster Water Cooling 5 July 18, 2009 08:10 PM
Mem. OC. High FSB vs Tight timings Gooses Overclocking, Tweaking and Benchmarking 1 September 3, 2008 09:31 PM
Tight Budget Overclocking! Digital_fx3 Overclocking, Tweaking and Benchmarking 18 April 27, 2008 03:52 PM
