Games, music, HW, other basic stuff, a bit of photoshop CS5, maybe some crunching and folding... other random stuff
Under 1500$ CAD
Mostly Canada
, but US also
4. IF YOU have a brand preference. That means, are you an Intel-Fanboy, AMD-Fanboy, ATI-Fanboy, nVidia-Fanboy, Seagate-Fanboy, WD-Fanboy, etc, etc, etc, you get the picture.
I am freaking neutral, hate fanboism
Well, I just bought a used i7 920 C0, AsRock Extreme x58, and some sweet 3x2gb kit of RAM
Oh and I need a very portable set of headphones, so I bought Koss KSC75 and I wanted some closed cans with good sound quality, so I got the Creative Aurvana Live!, both from the US, totaling <100$ CAD
Total for all ~570$
not really
Overclock at 3.8ghz
In about a week
9. What resolution do you use?
1920x1080 once I get my monitor
So what have a came up with? (btw, I need everything except what is listed in #5) Remember, this has to be under 930$ AFTER tax and insurance, this ends up like 870$
What do you guys all think?
