Old April 17, 2010, 10:38 AM
Question Two Builds for Final Review
With my last exams of undergrad coming to a close, it's almost time to order parts for two computers. Just looking for some comments before i buy all the stuff from NCIX (with PM) around Thursday this week.
The first one will be my computer, which is mainly for gaming, surfing, photoshop, and basic office stuff. I'm planning on doing a modest overclock on it, but i'm not going to push it too far since it'll be my first time. I plan on going SLI, putting in an SSD, and maybe a RAID array in a year or so.
Specs:
Case: Lancool K-60 (already bought)
Motherboard: Asus P7P55D-E pro
CPU: i5-750
Cooler: CM 212+
HDD: 1 TB Caviar black
DVD: basic LG DVD burner (already bought)
PSU: Corsair HX850W
RAM: 4GB of G.Skills F3 series
Video: some flavour of 5870
The second computer is one for my dad, as a retirement gift. He's on an old P4 1.4Ghz that's 8+ years old and its time for it to be replaced. He doesn't do anything intensive on his computer, but I figure if i build him something solid, he can keep it for as long as he's kept his current machine.
Specs:
Case: Antec P180 mini
Motherboard: GB H55M-USB3
CPU: i5-661
Cooler: Stock
HDD: 1 TB Caviar Black/ Spinpoint
Bluray: LG CH10LS20
PSU: Antec Earthwatts 500
RAM: 4GB of kingston valueRAM
Video: onboard
Tuner: Diamond TV Wonder 650 PCIe
Any comments would be greatly appreciated.
Edit: Case on 2nd build changed to a P180-mini from a P-183
Edit: dropped SSD and opted for a smaller, faster HDD for the 2nd build.
Old April 17, 2010, 12:34 PM
martin_metal_88's Avatar
Forst the first built, it's perfect just change nothing. Good part and well balanced! for the second rig I am wondering why you take a P183 + a 500W antec. I would go for something looking like a lascala LC17B or some Homt theater looking case and use a more silent PSU. The rig is good for sure and you can run it like this without any issue it was just a wondering.
Carry on and make a workblog these 2 will rock!
Ask for more
Martin_metal_88
Colenzo : See system spec!
Odysseus : I7 860 @ 3.6Ghz || GA P55-UD5 || G.skill Ripjaws F3-16000 2000Mhz 2X2GB || Coolermaster ATCS 840 || Silverstone Strider plus 850W || WD 640 black - WD 1TB green - Samsung F3 2TB || MSI 5670 1GB Cyclone ||Coolermaster Hyper 212 + ||
Old April 17, 2010, 12:45 PM
I wanted something clean for the case and wasn't really going to go into a media enclosure since I was thinking of it mainly being a computer for now, but i'll definitely look into different cases.
In terms of the power supply, did you have any particular quieter ones to recommend?
I'll definitely take lots of pictures when i put these two rigs together
Old April 17, 2010, 12:57 PM
The 500W Earthwatts should be basically inaudible at the loads that system will put on it. Noise is not a concern.
Old April 17, 2010, 01:16 PM
And the P183 is a "quiet" case especially if you change the tri cools for maybe Noctua fans.
"What is the colour when black is burnt ?" - Neil Young
Old April 17, 2010, 02:29 PM
0o0 0o0 is offline
I was just thinking, todays ssd's are supposed to last 50k writes per block.. does your dad know about ssd's? I would never give my parents an ssd, just based on the fact that they'd wear it out in 2 years. If you expect it to last that long, he probably wants to know the basics of ssd's. With that kind of money at your disposal, get some noctua's for sure, you won't be able to see the brown stuff from outside the 183.
Old April 17, 2010, 02:53 PM
You bring up a good point. I was going to just put windows and a bunch of applications (office, firefox, etc.) on the SSD and put everything else on the HDD including temp folder and the My Documents folder. My dad's pretty tech savy, he might be out of touch a little, but the drives on his current machine are partitioned, so i think it should be ok.
Any other tips for maximizing SSD life?
Old April 17, 2010, 04:53 PM
tangrisser's Avatar
For case, have you considered cases like the Antec?
NCIX.com - Buy Antec NSK3480 New Solution mATX Mid Tower Case 2X5.25 1X3.5 380W Black Front USB Sound & Firewire - NSK3480 In Canada.
This 380W is more than adequate since all Antec PSU are rated for continuous usage.
Just FYI, Watch out for Bluray drives because some of the drives will not support newer media even with firmware updates.
It seems like they are riddled with DRM that Bluray on PC seems to be majorly crippled.
It's kind of ridiculous for anyone to pay over 200 dollars for a drive and only to find out that '2010' will not play because of some DRM software issue and it's a 100 dollar update.
Not mine. I wouldn't watch 2010 unless they paid me...[secretly opens his vault full of terrible movies]
Check out my SALE page
Old April 17, 2010, 05:38 PM
EaGle1337's Avatar
380w is not enough to run a 5870. Many other manufacturers rate their power supplies for continuous usage too.
NCIX.com - Buy Silverstone Strider 850 Plus 850W Modular Power Supply ATX 24PIN 135mm Fan 67A 80+ Silver Black - ST85F-P In Canada.
another choice for a power supply as well, it's fully modular too.
edit:tangrisser i think i read your post wrong, please correct me if i did.
Old April 17, 2010, 05:42 PM
He's talking about the second rig, not the gaming PC.
Two new builds Graysccale New Builds 7 February 21, 2010 05:22 PM
TWO new builds Jim Johnstone New Builds 14 December 6, 2009 05:47 PM
Need help on 2 builds(budget) belinik New Builds 4 September 17, 2009 06:09 PM
Builds? CactusJoe New Builds 3 October 28, 2008 02:39 PM
Final review of my build before ordering! Wein13 New Builds 20 September 10, 2008 10:59 AM
