Old April 13, 2010, 09:00 PM
Originally Posted by andynerd View Post
Does this ram look like a better choice? http://ncix.com/products/index.php?sku=24600
Dang I need a new PSU with that motherboard my old one doesn't have the 8 pin connecter, i'm thinking a 650w corsair.
That RAM seems fine, in fact any RAM will do for a budget build so just try to pick up a kit when it's on sale or something. However don't always expect to get a good OC on cheap RAM- it's something that comes with the 'value' territory.
The 650W PSU will definitely work but it's way more than enough juice for your current configuration. Of course you can get it now and keep it for future builds or if you decide to throw in a graphic card one day, otherwise you can save some cash and go with a 400W one.
Old April 13, 2010, 09:22 PM
youre paying wayy too much for a dual core. x4 630 is 100 bucks. for amd, gigabyte all the way. one or two pci-e lanes, chipset 780 and up will do you good. go for the ud4p if you find it in stock ,else below 100 you can find a couple
if you already have ddr2 from your old system, then its a no brainer.
212+ for the win!
Old April 14, 2010, 09:57 AM
andynerd's Avatar
I don't have any ddr2 from the old computer setup i had a pentium D with 2 gb of ddr. Also I think it is a fair price for a cpu and I can always price match it for a slightly cheaper price. I was hopping to get a phenom series processor. Not to mention the few places I looked had the 630 for $120-135.
"let the geek be with you"
Specs: Asus G74SX
Old April 14, 2010, 10:38 AM
Buy AMD [ADX630WFGIBOX] AMD Athlon II X4 630 Quad Core Processor Socket AM3 2.8GHZ 2MB Cache 95W Retail Box
Back to: Home > Components > Processors (CPUs) > AMD Athlon II X4 630 ...
Do more of the things you want to in less time and enhance your digital life with the multi-core performance and energy efficiency of AMD Athlon II processor-based desktop systems. Combined with superior ATI Radeon HD graphics technology, systems based on the AMD Athlon II processor deliver a vivid visual experience, superior multi-tasking, and exceptional digital media performance with next-generation energy efficiency.
Photos may not resemble actual product and are purely for illustration purposes
$99.79 Canadian Funds
Reg. Price $112.17 Save $12.38
Limit 1 per customer , Only 79 left at this price!
In Stock
(usually ships in 1-2 business days)
Stock Check: Vancouver ( > 20 )
Toronto ( 270 )
Add to Wish List
SKU: 220890
VPN: ADX630WFGIBOX
Shipping Weight: 1.5 lbs
More products from AMD
Customer Reviews: Write a review.
pricematch away
Old April 14, 2010, 05:26 PM
andynerd's Avatar
What is the difference between the athlon and the phenom? On the website the 555 is 10 dollars more then the 630 you linked me. Is it worth it or still a rip?
Specs: Asus G74SX
Old April 14, 2010, 05:43 PM
chrisk's Avatar
Folding Captain
The new NCIX sale is tonight. might be worth a look to see if they have any bundles for sale or anything.
Also check out the Buy/Sell section...maybe somebody will cut you a deal.
Fold for team #54196
Budget Build! Toyuko New Builds 4 April 12, 2010 08:19 AM
Budget Build Paganitzu New Builds 4 March 14, 2010 03:23 PM
Budget build. Epmphasis on budget. Miek New Builds 6 February 4, 2010 10:46 PM
Budget Build x 2 Burkdaddy New Builds 4 January 28, 2010 08:18 AM
Budget build! JMCD New Builds 10 April 17, 2009 07:25 PM
