<~----> New build help - Hardware Canucks
Old April 1, 2010, 08:33 PM
Default New build help
Hi guys, just put together another PC, and having a minor issue.
When I reboot my computer, it completely shuts it down (power is completely cut off), and drives stop spinning, so then they have to spin up again. Before I reopen the case and start fiddling around, could it be because my jumpers are wrong? or maybe this is just the way this motherboard is?
My motherboard is a GA-P35-DS3L.
Any input would be greatly appreciated.
Thanks!
New on HWC but lots of feedback on RFD (89-0-0)
XBMC Rig (1900PPD): AMD Athlon II X2 240 @ 3.2ghz | Gigabyte GA-MA78LM-S2H | G.Skill 2GB DDR2 800 | WD Caviar Blue 500GB | Antec NSK1300 SFF Case
Folding Rig: (1700+4500PPD) Intel Core 2 Duo E6600 | Gigabyte GA-P35-DS3L | OCZ Special Ops 2GB DDR2 800 | EVGA 9800GT | G.Skill Falcon 64GB SSD | Samsung Spinpoint 1TB | Seagate Momentus 1TB | Generic ATX 430W Case
Old April 1, 2010, 08:41 PM
how do you reboot? start, shut down, reboot? or do you press the button on the case? you could have that vice versa
Old April 1, 2010, 09:25 PM
Start -> Restart
or even when I exit bios and the computer restarts itself, this happens.
Old April 1, 2010, 09:29 PM
SugarJ's Avatar
A little clarification please. Does it boot normally after the drives spin back up? Or do you have to power off?
Old April 1, 2010, 09:31 PM
hmm..unless you have a mad overclock and it goes in safe mode or something, somethigns not right there
Old April 1, 2010, 09:36 PM
Yes, it boots normally. I think dangtx hit the nail on the head, I was playing with overclocks (through EasyTune), must have made it unstable
Thanks guys!
Windows 7 Build 7000 VS Windows XP SP3 Build 2600 Benchmarks Veritas Overclocking, Tweaking and Benchmarking 3 March 3, 2009 01:48 PM
Critique my gaming build build 1080p New Builds 10 January 14, 2009 03:18 PM
