Old April 6, 2010, 06:03 PM
Originally Posted by Ryoohki View Post
Well. 2500$ might seem overkill.. here's my rig run down
CoolerMaster HAF932 case : 150$
Intel I5 750 : 209$
Powercolor PCS+ 5850x2 (Xfire): 304x2
8 Gig of ram : 113+115$
Antec 750W PSU : 125$
NZTX Fan Controller : 35$
Thermalright MUX-120 : 45$
Intel 80G SSD : 235$
1TB WD Green : 88$
Gigabyte P55M-UD4 : 160$
So about 1900$+5% (taxes) = 2000$ (approx)
And i think i have a overkill gaming machine...
Nothing against your suggestions but I would suggest going with an:
i7.
about 100 more Watts of power.
Cut down to 6 gigs of ram.
cut the fan controller
Cut theSSD
Go for 5870's instead of 5850's.
Replace the MUX-120 with a Noctua NH-D14 <-- best air cooling in the business, beats a Corsair H50 too. Then again if you're not OC'ing the CPU I guess there's no need for the D14
Old April 6, 2010, 09:33 PM
punk_zappa's Avatar
I like the OP's thinking, plan and absorb the advise. I like the underdog comment as well. Whatever you prefer, it will surely last you a long time. My only gripe about your build is that it will take you 5 months to get everything and who knows what might come out between those times that might change your mind.
Old April 6, 2010, 10:03 PM
MonsterSound's Avatar
methinks there is some room for debate on an i7 860 vs. the i5 750.
For a gaming machine I personally would chose the i5 750.
The i5 is cheaper, runs cooler and is a great overclocker which easier to overclock.
Additionally, most games/apps can't utilize the HT/ v 8 thread capability of the i7.
Code:
 my Heatware,  RFD &  eBay
MAIN: i5 3570 @ 4.5Ghz wH100 / evga GTX780 SOC / MSI Z77A-G45 / 8gb G.Skill 2133 1T / 30" 2560x1600 / Antec P280 / PCP&C 950w / Intel 520 SSD 240gb / Eclipse / G3-Lazer / z5300 / Win7 Pro64 / APC Xs1300
HTPC : nMedia6000B / AMD X2 4400+ / M2A-VM / Corsair 4GB 800 / LiteOn Blu-Ray / 8800GT / Samsung 46"LCD / 2x2TB / OCZ500 / ATI550 / Wrless Kbrd & Rmte / z-5500 / Win7Pro / APC700
"You must be the change you want to see in the world"
- Mahatma Gandhi
First ever Gaming rig build. gambel626 New Builds 5 November 2, 2009 08:32 AM
No budget multimedia/gaming rig build. Viceroy New Builds 35 October 21, 2009 12:14 AM
1st build gaming rig questions aviduser New Builds 5 February 9, 2009 12:33 PM
Going to build my first gaming rig Zankras New Builds 11 October 19, 2008 04:53 PM
New gaming rig/first build need feedback ITaoI New Builds 23 October 16, 2008 08:00 AM
