  #21 (permalink)
Old April 11, 2010, 09:43 AM
AmuseMe's Avatar
The H50 is not a water cooler... There are air coolers that can perform better Still a nifty little product.
DEAD CA$H
  #22 (permalink)
Old April 11, 2010, 09:45 AM
Originally Posted by G777 View Post
Just curious, why 12G's of ram?
The HAF932 is my work system, or at least the system I access work on. It has all my VM instances, using Virtual Box as it works for me and it's free. On this system I often need and I'm unable to run 3 VM's at the same time. That system I'm hunting for 24GB of RAM which I'll write off as a non compensated expense to employment for 2010 tax year. Basically everything in that box is a write off, and depending on my usage of the HEC98 build it might be too.
The HEC98 build will be a gaming system, and due the budget for Video cards as I'm going to run 4 way on the board I looking to save money. In fact I'm going to probably cut it back to 6GB as 12GB for gaming isn't going to give me anything and the money would be better spent on dual SSD drives. I have picked up a single Intel M-25 160GB on eBay for 330.00 CAD actively looking for a partner for it now.
  #23 (permalink)
Old April 11, 2010, 10:22 AM
G777's Avatar
Nice deal on the SSD! I have the 80gb version, and I love it. Can't imagine anyone who has used one ever going back to a mechanical HD. Unfortunately I cant expense my computer purchases
  #24 (permalink)
Old April 12, 2010, 08:40 PM
advise which PS I should look for with my 170-BL-E762-A1 board, I will be running four cards on it (question is it only the classified cards that can run 4 way on this board)? Thinking I need a => 1200W PS
Tags
9800 , asus p6t , karmic , watercooling
Help me finalize my 1st build #2 kaufman37 New Builds 22 August 21, 2009 10:17 AM
Help my finalize my 1st build kaufman37 New Builds 20 August 18, 2009 11:10 PM
Help me Finalize my 1st Build kaufman37 New Builds 8 August 9, 2009 10:45 AM
1st Post, new build, what do you think? Cowinacape New Builds 16 July 31, 2008 09:05 PM
Stuck on my 1st build Mr. Cipher Troubleshooting 9 November 2, 2007 01:36 PM
