Old March 20, 2010, 04:03 PM
MarkOne's Avatar
Default Ubuntu Ultimate machine
ok I ask it on the Ubuntu forum and peoples don't have the same criteria for Ultimate
so for the one who are using Ubuntu or similar Distro, what wil be your ultimate machine to have the fastest desktop, of course with out spending for nothing , Last one I build was using a P IV and I was not satisfy with the performance.
4, 6, 8, or 12 gb of Ram
4, cores or 8 ( including HT)
is Amd powerfull enough , or I will see a difference with a i 920
what is the best graphic card, or combinaison for 3 LCD ( 22 or 24" )
and no need to tell that Windows 7 or a Mac will be better, I have also them
Old March 20, 2010, 04:09 PM
Digikid's Avatar
Well Ubuntu is pretty powerful as it is. It does not need a lot of ram or CPU cycles.
Not really sure what to say here.....I guess that a i7 920 is more than powerful enough for Ubuntu.....and depending if you are running any Virtual Machines or anything When it comes to RAM....more is always better. :)
Old March 20, 2010, 04:22 PM
gingerbee's Avatar
run a socket 1156 and 4 gigs more then enough ( i don't use ubuntu alot but I thought it didn't need that much to run pretty good )
Old March 20, 2010, 05:03 PM
MarkOne's Avatar
what about a 965 black ( AMD not my 965 EE )
Old March 20, 2010, 05:29 PM
gingerbee's Avatar
well i think that should do just fine.
Old March 20, 2010, 05:32 PM
MarkOne's Avatar
do just fine
I said ULTIMATE
Old March 20, 2010, 06:28 PM
I would say that for normal use, any half-decent dual-core CPU and 2GB of RAM or so would be more than enough. Ubuntu 9.04 runs without a hitch on my secondary PC, and you can see the specs for that in my signature. You say ultimate, but if you're talking about just desktop usage, you won't see any real difference between a decent machine and a super high-end rig.
Old March 20, 2010, 08:03 PM
Digikid's Avatar
Wait....are you talking about Ubuntu Ultimate Edition???? Or are you wanting an Ultimate PC for just plain Ubuntu?
Old March 20, 2010, 08:46 PM
gingerbee's Avatar
i think he's talking about Ubuntu Ultimate Edition and form what i can tell yes that chip would be great most run it on much lower specked system's on the ubuntu forums
Ultimate Edition 2.3 | Ultimate Edition
Old March 21, 2010, 05:28 AM
MarkOne's Avatar
did I said Ubuntu Ultimate Edition Machine ? ....no plain Ubuntu.
64 Bit Vista Ultimate and Office Ultimate 32 Bit tyreman O/S's, Drivers & General Software 5 March 22, 2009 04:54 AM
Machine burnt out. New machine needed Neutronium New Builds 15 March 18, 2009 12:23 AM
Ubuntu not booting Wein13 O/S's, Drivers & General Software 12 September 27, 2008 09:41 AM
Ubuntu 8.04 miggs78 O/S's, Drivers & General Software 3 August 7, 2008 04:06 PM
The ultimate Halo 3 suicide machine Babrbarossa Gaming 2 December 28, 2007 10:44 PM
