hey there, i apologize if this is in the wrong section, i can move it if so.
before my questions here is the mandatory list
1. What
YOUR PC will be
used for. That means what types of
tasks you'll be performing.
gaming only
2. What
YOUR budget is. A
price range is acceptable as long as it's not more than a 20% spread
500 CAD
3.
What country YOU will be buying
YOUR parts from.
Canada
4. IF
YOU have a
brand preference. That means, are you an
Intel-Fanboy,
AMD-Fanboy,
ATI-Fanboy,
nVidia-Fanboy,
Seagate-Fanboy,
WD-Fanboy, etc, etc, etc, you get the picture.
motherboard wise i only like asus or gigabyte, more leaning towards asus.
5. If
YOU intend on
using any of
YOUR current parts, and if so, what those parts are.
case, powersupply (750 watt antec) a bunch of sata harddrives, ide dvd drive, monitor
6. IF
YOU have
searched and/or
read similar
threads.
i cant seem to find any answers to my questions
7. IF
YOU plan on
overclocking or run the system at
default speeds.
default
8.
WHEN do you plan to build it?
june 2010
9. What
resolution do you use?
1440x900
Okay so here goes, i am getting two 5770's for a
good price
and would like to use both in a crossfire setup, Why? because i never did this and i would like to try,
Does the motherboard need to have two pciexpressx16 slots or can one of them run x16/x8
or x8/x8? Or does this not even matter for these cards?
So all i need is a motherboard, cpu and ram. the cheaper the better. any help will be appreciated thank you.
