Old March 13, 2010, 01:28 PM
Default First Build
Hoping to build my first computer and was hoping to get some opinions from fellow Canadians. I made a public wishlist on Newegg so check it out:
Newegg.ca - Once You Know, You Newegg
Hoping to use it on my HDTV for minor gaming, linux virtualboxes, school, video conversion/transfer and finally to learn how to build a pc.
The harddrive and powersupply have good deals this week on newegg, overall the total with tax and shipping is $810.
Thanks!
Old March 13, 2010, 01:35 PM
Raserei408's Avatar
There are some changes I'd suggest making, but none that don't involve raising the budget. What you've got is still a pretty solid build.
"If dancing is sure to result in failure then you must dance anyway."
Lo Mein said that, and I think he knows a little more about dancing than I do pal, because he invented it! Then he perfected it so that no man could best him in the club of honor.
Then he used his prize money to buy two of every whore on Earth. Then he herded them all onto a boat, then they all beat the crap out of every single one of him.
Old March 13, 2010, 01:49 PM
What did you have in mind? I understand that the video card is about a generation off, but honestly the type of gaming I'm looking at is mostly old RTS, 2d MMO and maybe like Wolf ET :P. I've been out of the PC gaming world that I'm not even sure what to play, I dunno Starcraft II?
What I'm mostly concerned about are the Harddrive and Powersupply. I've yet to really find any good info about 32mb cache vs 16mb for Harddrive and I'm just afraid that my powersupply will either die or just not work with the mobo!
You should also understand that this upgrade is from a 1.6GHZ P4 with like 750mb ram and an ancient nVidia card. I'd be happy if this new build lasts 3/4 as long as that old thing has!
Windows 7 Build 7000 VS Windows XP SP3 Build 2600 Benchmarks Veritas Overclocking, Tweaking and Benchmarking 3 March 3, 2009 02:48 PM
