Old February 20, 2010, 07:42 AM
Default Building a new I7 system
Hello.
I'm currently in the midst of assembling a new gaming system, although I'm unsure on which motherboard to choose.
The system is as follows:
Intel I7 920
XFX 5870 x 2
6 x 2gb Kingston Hyperx 1600mhz
Corsair HX1000w
Intel 80gb SSD
I was looking at the Asus P6T Deluxe V2, but I am unsure wether it would be the best choice for my setup?
I hope you can help.
Old February 20, 2010, 08:03 AM
MarkOne's Avatar
Welcome to the board, you have a very good build here, what case are you planing to use ?
the p6T deluxe v2 is a good board for stay in the same budget the rampage II gene have a better sound card but it's a micro atx
Old February 20, 2010, 08:05 AM
BigDogg's Avatar
Originally Posted by billionaireclub View Post
Hello.
Intel I7 920
XFX 5870 x 2
Corsair HX1000w
Intel 80gb SSD
I can't speak for the Asus but I can recommend the Gigabyte UD5. I really like this board as it offers great overclocking, performance, and has all the features I needed. It can do TRI-Crosfire and SLI. There is also the EVGA X58 boards which many recommend.
NCIX.com - Buy Gigabyte EX58-UD5 ATX LGA1366 X58 DDR3 3PCI-E SATA2 Sound 2GLAN 3-WAY CrossFireX SLI Motherboard - GA-EX58-UD5 In Canada.
Old February 20, 2010, 08:07 AM
Thank you
I have a Coolermaster HAF fulltower.
Sound doesn't really matter, I use a USB headset and I can always add a new soundcard if needed.
Old February 20, 2010, 09:52 AM
May I suggest you go for a 5970 instead? It's like $200 cheaper and as far as I understand you can easily overclock it to be the same performance as 2 5870s..
If you have a HAF, you can easily fit it too..
Old February 20, 2010, 10:03 AM
Well the thing is, im starting with 1 graphics cards and then later adding another, when I can afford it.
Old February 20, 2010, 11:39 AM
prozac26's Avatar
I have the Gigabyte X58A-UD5 motherboard, and I love it. USB3.0 and SATA3. The mobo in the link BigDogg provided is the same, except it doesn't have USB3.0 and SATA3.
http://ncix.com/products/?sku=49015&...cture=Gigabyte
Old February 20, 2010, 11:54 AM
What is the difference between the UD5 and UD7? The price is only a minor difference.
Old February 20, 2010, 01:01 PM
BigDogg's Avatar
The main difference is Sata 3.0 and USB 3.0 which the EXA-UD5 also has. The UD7 also comes with some watercooling capabilities already in place. I have the regular EX-UD5 non Sata 3.0 and USB3 and this is one of the best boards I have owned.
Old February 20, 2010, 05:52 PM
Gotcha. That's understandable.
By the time you can afford it, the price will be better for sure as well..
I think ATI is coming out with a refresh pretty soon.
Building a Intel i7/X58 System.. need your expertise. exxoid New Builds 18 May 16, 2009 10:55 PM
Building a budget system around a 4850x2 Vethrik New Builds 14 March 5, 2009 05:49 AM
Building a new system $2800 budget probationer New Builds 51 November 3, 2008 02:35 PM
Building a gaming system around 1200$ Muad'Dib_53 New Builds 4 August 9, 2008 04:30 PM
Building a Dual Socket System Paul Rogers CPU's and Motherboards 8 February 6, 2008 05:01 PM
