<~----> Need help with an 800$ build. - Hardware Canucks
Old February 15, 2010, 08:01 PM
Trial Member
Default Need help with an 800$ build.
Hello Hardware Canucks,
As you can probably see by my post count, I'm a total newb here. I have come to this lovely forum in search of help, specifically, help with making a computer. I remember being entangled in this scene 2-3 years ago, back when I was building my first gaming comp. I have, however, since then, not dabbled in keeping up with the news and I have completely fallen behind. I have searched the forum for topics very similar to what I am going to ask, but, I found the multitude of answers too confusing (in the sense that, I couldn't find one exact build that suited what I needed). I hope you can help me; I shall now fill out the survey.
Some pretty intensive gaming, mostly online. I also multitask quite a bit, having lots of the Adobe Suite open at one time.
I have 800$ (CAN) total. That's with shipping and handling, taxes, etc. My complete and total unburstable limit is 850$.
Canada!
4. IF YOU have a brand preference. That means, are you an Intel-Fanboy, AMD-Fanboy, ATI-Fanboy, nVidia-Fanboy, Seagate-Fanboy, WD-Fanboy, etc, etc, etc, you get the picture.
Honestly, I don't know anymore. Before I really liked nVidia and Intel, but, I am aware things have changed and I'm not gonna be picky about it.
Just my current mouse, keyboard, and monitor.
I certainly have, but I find all of them either go too high (budget-wise) or too low.
If it's gonna run smooth and stable, I'll overclock for sure.
Sometime in the next 3 months; most likely very soon.
9. What resolution do you use?
Currently I'm using 1280x1024, and I'm gonna use the same one with my new PC. But that is only temporarily as I plan on buying a better monitor (22") later down the road, when my budget permits me doing so.
Anyway, I'd be really glad for the help.
Old February 15, 2010, 08:35 PM
ZZLEE's Avatar
Default Over buget but just idea
PC Builder Preview
This system is close to 1000.00. Price match or see if you can find parts on sale. Just an Idea of what I would build right now.
Welcome to the forums
"EVGA hunted down the last dozen or so expats living in Karachi." SKY
Old February 23, 2010, 05:40 PM
guitarzann's Avatar
Heres a build for you:
CoolerMaster Elite 310 Case: http://ncix.com/products/index.php?sku=39592
Gigabyte GA-770TA-UD3 Motherboard: http://ncix.com/products/index.php?sku=47584
AMD Phenom II X4 945 CPU: http://ncix.com/products/index.php?sku=50691
Sapphire Radeon HD 5770: http://ncix.com/products/index.php?sku=49770
OCZ Platinum 4gb RAM: http://ncix.com/products/index.php?sku=42869
OCZ Z-SERIES 650W Power Supply: http://ncix.com/products/index.php?s...6&promoid=1139
Western Digital Caviar Black 500GB Hard Drive: http://ncix.com/products/index.php?sku=33883
Samsung DVD-RW: http://ncix.com/products/index.php?sku=46792
Antec 120mm Case Fan(x2): http://ncix.com/products/index.php?s...ufacture=Antec
Total(After Mail-In Rebates, no shipping): $824.42
Remember, this has NO OPERATING SYSTEM INCLUDED.
800$ 720p gaming build complete johnnyblazzwa New Builds 5 January 26, 2010 08:15 PM
Newbie high-end build for $800 Xuco New Builds 14 August 4, 2009 05:53 PM
$700-$800 Build smithereen New Builds 10 July 8, 2009 04:09 PM
Is $800 enough to build a decent gaming computer? Youssef New Builds 22 March 3, 2009 05:52 PM
$800 Budget Gaming Build Zayxic New Builds 24 November 25, 2008 07:38 PM
