  #21 (permalink)
Old February 9, 2010, 12:54 PM
rjbarker's Avatar
I will wait to see the GTX 470 before buy a new GPU. even if the price tag is to high
Yeah I think thats my next upgrade now...a couple of Fermi GTX 470 / 80's likely around a grand ....will be dumping the 280's for about $170 / each.(one is already boxed up)....the Folders here maybe interested ;)
Tri SLi "Procyon"
http://i30.photobucket.com/albums/c3...ant2/nice2.jpg
Evga 4.2 Ghz Club....
Tri SLi 580 MK11
http://i30.photobucket.com/albums/c3.../MK11Multi.jpg
Tri SLi 580 Vantage
http://i30.photobucket.com/albums/c3...ant2/60K-1.jpg
......Remember, keep your head up....and your stick on the ice
  #22 (permalink)
Old February 9, 2010, 12:59 PM
Fudd Rucker's Avatar
They have to get them out first. They finally just got a name out lol. I dont forsee a DX11 nv gpu out for quite some time and when it does it will be in the usual NV fashion of $500 as a starting price for even the lowest of the high end.
Swiftech MCP-655 | EK Supreme Acryllic
XSPC 360 | DD Dual 5.25"
Primochill 1/2" Tubing | 3 x 38mm Kaze 3000rpm
EK Nickel GTX 480
  #23 (permalink)
Old February 9, 2010, 01:02 PM
rjbarker's Avatar
^^^^ Yeah your likely right...no doubt the "higher end" models (that I'll want) will be closer to $650 ea.....ouch...oh well.....
Tri SLi "Procyon"
Tri SLi 580 MK11
Tri SLi 580 Vantage
  #24 (permalink)
Old February 9, 2010, 01:06 PM
MarkOne's Avatar
Originally Posted by Fudd Rucker View Post
I game a lot as well as a production machine, so the 5870 was cheap considering my other alternatives and seems to work great.
don't quote me too much on that, rant: I have have always been an ATI fan Boy, but frankly at the price tag they put the 5870, they just abuse of the situation, and make loyal customer for it. What justify the 100 % price increase from 4890 to 5870 (end of the rant )
My point related to the topic, is wait few week if you can to see what happen, it's not a good time presently to buy a GPU. ATI or Nvidia
  #25 (permalink)
Old February 9, 2010, 01:12 PM
Guess you dont remember teh whole 8800GTS(650 bucks/1k GTX) price gougng lol.And when the 2xxx series card flopped, nvidia still continued to gouge the customer because there wasnt anything to compete with even among the nvidia offerings. And that gouging remained until the 3870 came out.
EK Nickel GTX 480
  #26 (permalink)
Old February 9, 2010, 01:51 PM
MarkOne's Avatar
you have a DAM good argument here.
  #27 (permalink)
Old February 9, 2010, 08:06 PM
Thanks for the input.
Would a 5870 be just stupid overkill for my monitor, 40" 1920 by 1080? I don't mind a little overkill, I'm a belt and suspenders kind of guy, but is it too much?
Any good alternatives to the cm 690 case? The cabinet it will be i.n makes access to ports and switches on the sides very awkward. The front works best for that stuff.
Finally, any online suppliers to avoid? I've used Newegg, Tigerdirect and Directcanada before. The products arrived ok but the Directcanada shipping was a gongshow
  #28 (permalink)
Old February 9, 2010, 08:29 PM
Raserei408's Avatar
A 5870 is overkill, quite honestly, for a 1920 x 1080 screen. A 5850 (ideally) or a 5770 (> adequate) would suit you fine for a fair bit less. It's just that, based on your budget it's the card to get. If you're willing to drop down to 1250-1500 CAD then you're in 5850 territory (lol).
Sadly there aren't really many cases that will get you most of the connectors on the front. However, there are some that will give you 4 USBs up front, which will be helpful. You might look into the Storm Scout, which has 4 front USB ports and an e-SATA.
"If dancing is sure to result in failure then you must dance anyway."
Lo Mein said that, and I think he knows a little more about dancing than I do pal, because he invented it! Then he perfected it so that no man could best him in the club of honor.
Then he used his prize money to buy two of every whore on Earth. Then he herded them all onto a boat, then they all beat the crap out of every single one of him.
  #29 (permalink)
5870 is a badass card all around. I use mine for 1920 x 1200 resolution and the framerate is phenominal. Add a cheap nvidia 8600 series or higher card for physx(hacked drivers) and your good for some time i think for gpu, and if need be add a 2nd 5870 later when they are cheaper.
NCIX is pretty good when it comes to price matching and going with air shipping. Processing time can be lengthy at times but they usually come through on the price match which is a bonus.
EK Nickel GTX 480
  #30 (permalink)
Old February 9, 2010, 08:38 PM
Raserei408's Avatar
Yes, the framerate is phenomenal. In fact, you're probably getting > 60FPS in almost all games. That's called overkill. A 5850 will get similar framerates (less, but not noticeably so) and save about $100.
Also, if you want dedicated PhysX, the best way to go is a GT240. It's weaker than a 9800 GT, but oddly it eats the 9800 for breakfast in PhysX.
Input on build Nemis79 New Builds 1 November 2, 2009 01:56 PM
Input Lag Cranky Gaming 4 July 26, 2009 02:14 PM
Input guys shayan288 Gaming 6 November 9, 2008 10:17 PM
Need some fresh input Supergrover Troubleshooting 1 October 23, 2008 08:30 PM
need input flybye Overclocking, Tweaking and Benchmarking 4 September 11, 2007 03:34 PM
