| Quote:
__________________ Swiftech MCP-655 | EK Supreme LT Arcryllic Swiftech MCR220 | Swiftech MicroRes Primochill 1/2" Tubing | 2 x Yate Loon |
Why are we talking about overpriced ATI here... 58xx are overpriced and 57xx are... let say not quite a gamer dream. Will not put a $ 150 GPU in a 1366 rigs.. as for xfire... well you all know what I think about it. I will wait to see the GTX 470 before buy a new GPU. even if the price tag is to high... chances are that it will make drop the one of the High End ATI
__________________ |
| Quote:
I had a similar experience with Antec, and I'll never buy/recommend one of their PSUs again. Last edited by Hunt; February 9, 2010 at 11:28 AM. Reason: self enforced grammar police |
I game a lot as well as a production machine, so the 5870 was cheap considering my other alternatives and seems to work great.
| Quote:
__________________ See "My System Specs" For Primary Rig > 2nd Rig E8400 @ 4.05 Ghz Evga 780i 2 x 2GB Mushkin Redlines @ 1000 Mhz 74 GB Raptor (OS) 320GB Barracuda (Data) 2 x Evga 9800 GTX+ SLI - OC'd of course!! 750W PC P&C W7 HP x64 NoteBook: Asus G51J A1 I7 720QM 1.6Ghz - 2.8Ghz (Turbo Mode) 2 x 2GB DDR3 1066 Mhz @ 1150 Mhz (7-7-7-20 1T) GeForce GTX 260M 1 x 80GB Intel G2 SSD 1 x 320 GB Seagate Momentus 7200 RPM 15.6 "1920 x 1080 HD W7 HP x64 . |
They have to get them out first. They finally just got a name out lol. I dont forsee a DX11 nv gpu out for quite some time and when it does it will be in the usual NV fashion of $500 as a starting price for even the lowest of the high end.
^^^^ Yeah your likely right...no doubt the "higher end" models (that I'll want) will be closer to $650 ea.....ouch...oh well.....
| Quote:
rant: I have have always been an ATI fan Boy, but frankly at the price tag they put the 5870, they just abuse of the situation, and make loyal customer for it. What justify the 100 % price increase from 4890 to 5870 (end of the rant ) My point related to the topic, is wait few week if you can to see what happen, it's not a good time presently to buy a GPU. ATI or Nvidia
Guess you dont remember teh whole 8800GTS(650 bucks/1k GTX) price gougng lol.And when the 2xxx series card flopped, nvidia still continued to gouge the customer because there wasnt anything to compete with even among the nvidia offerings. And that gouging remained until the 3870 came out.
| Quote:
you have a DAM good argument here.
Thanks for the input. Would a 5870 be just stupid overkill for my monitor, 40" 1920 by 1080? I don't mind a little overkill, I'm a belt and suspenders kind of guy, but is it too much? Any good alternatives to the cm 690 case? The cabinet it will be i.n makes access to ports and switches on the sides very awkward. The front works best for that stuff. Finally, any online suppliers to avoid? I've used Newegg, Tigerdirect and Directcanada before. The products arrived ok but the Directcanada shipping was a gongshow |
A 5870 is overkill, quite honestly, for a 1920 x 1080 screen. A 5850 (ideally) or a 5770 (> adequate) would suit you fine for a fair bit less. It's just that, based on your budget it's the card to get. If you're willing to drop down to 1250-1500 CAD then you're in 5850 territory (lol). Sadly there aren't really many cases that will get you most of the connectors on the front. However, there are some that will give you 4 USBs up front, which will be helpful. You might look into the Storm Scout, which has 4 front USB ports and an e-SATA.
__________________ "If dancing is sure to result in failure then you must dance anyway." Lo Mein said that, and I think he knows a little more about dancing than I do pal, because he invented it! Then he perfected it so that no man could best him in the club of honor. Then he used his prize money to buy two of every whore on Earth. Then he herded them all onto a boat, then they all beat the crap out of every single one of him. |
5870 is a badass card all around. I use mine for 1920 x 1200 resolution and the framerate is phenominal. Add a cheap nvidia 8600 series or higher card for physx(hacked drivers) and your good for some time i think for gpu, and if need be add a 2nd 5870 later when they are cheaper. NCIX is pretty good when it comes to price matching and going with air shipping. Processing time can be lengthy at times but they usually come through on the price match which is a bonus.
Yes, the framerate is phenomenal. In fact, you're probably getting > 60FPS in almost all games. That's called overkill. A 5850 will get similar framerates (less, but not noticeably so) and save about $100. Also, if you want dedicated PhysX, the best way to go is a GT240. It's weaker than a 9800 GT, but oddly it eats the 9800 for breakfast in PhysX.
| Thread Tools | |
| Display Modes | |
Similar Threads | ||||
| Thread | Thread Starter | Forum | Replies | Last Post |
| Input on build | Nemis79 | New Builds | 1 | November 2, 2009 12:56 PM |
| Input Lag | Cranky | Gaming | 4 | July 26, 2009 01:14 PM |
| Input guys | shayan288 | Gaming | 6 | November 9, 2008 09:17 PM |
| Need some fresh input | Supergrover | Troubleshooting | 1 | October 23, 2008 07:30 PM |
| need input | flybye | Overclocking, Tweaking and Benchmarking | 4 | September 11, 2007 02:34 PM |
