  #21 (permalink)
Old February 8, 2010, 11:03 PM
Not sure I agree with your reasoning.
Not so long ago a 450-500 watt power supply was considered high end. I doubt anyone is using the PSU they bought back then in their main rig (since it was probably only 20 wires and might not have had the power connections PSU's do today.), and 5 years from now, what's decent now will be a joke. Hell, in 5 years ATX could very well be depreciated and replaced with another standard. The power supply might blow out just out of warranty, too. (edit) 7 year warranty. nm!
Since the computer is being built for someone else, maybe it's better to just ask the girlfriend what she wants and go with that instead. If she didn't upgrade her old computer all that much since owning it, well, history tends to repeat itself.
Originally Posted by Raserei408 View Post
Honestly, I might recommend the 650TX, but not much lower than that. It's still more than the rig needs, but here's a secret...
It's called OVERHEAD. Who knows what'll happen within the life of this PC? Maybe they'll add a big, powerful GPU to it, maybe it'll be used for the next build or two when more power is required. Furthermore, since PSUs' maximum wattage goes down as the capacitors age, it's good to get a beefy one if you'll be using it for a long time.
  #22 (permalink)
Old February 9, 2010, 06:06 PM
Definitely don't skimp on the monitor. It's the part you have to look at!
  #23 (permalink)
Old February 9, 2010, 06:51 PM
MarkOne's Avatar
Originally Posted by b1lk1 View Post
5770 is super duper overkill. Even a 5750 is far more than she'd need. I have a 5770 and I can pretty much max out most new games. That is quite the Frankenstein build, ..
I was ready to make a joke about using a $ 150 GPU with a $ 1000 CPU but I look at your spec
you now running on a i5 ?? what happen to your Frankenstein i7-965, I was so jealous
  #24 (permalink)
Old February 9, 2010, 07:41 PM
Raserei408's Avatar
This PC is for his girlfriend who's into MMOs. As for the 965...*cough*ripoff*cough*. Only Extreme edition that's even marginally worth it IMO is the 980X.
"If dancing is sure to result in failure then you must dance anyway."
Lo Mein said that, and I think he knows a little more about dancing than I do pal, because he invented it! Then he perfected it so that no man could best him in the club of honor.
Then he used his prize money to buy two of every whore on Earth. Then he herded them all onto a boat, then they all beat the crap out of every single one of him.
  #25 (permalink)
Old February 9, 2010, 08:10 PM
clone63's Avatar
Athlon II x2 $70
785G mobo $90
4GB DDR3 $90
500W PSU $60
WD Black $80
any DVDRW $20
=$410. Probably 450 after tax and all the bs.
Used 4850? 80 bucks I've seen em go for.
  #26 (permalink)
Old February 9, 2010, 08:32 PM
Raserei408's Avatar
I'd go with a PII 550 / 555, 770T, TX650 and Spinpoint F3 1TB or Caviar Black 640, but yeah, that would run MMOs fine.
  #27 (permalink)
Old February 10, 2010, 04:31 AM
MarkOne's Avatar
I was not talking to the OP
useless provocation, not for me , for the one who own those kind of CPU on this board.
sound to me like the comment of a jealous person thant can afford it
  #28 (permalink)
Old February 10, 2010, 06:39 AM
Raserei408's Avatar
No, it's just that the extra $700 it costs gets you marginal speed increases and an unlocked multiplier (which only costs about $20 on AMD CPUs).
  #29 (permalink)
Old February 10, 2010, 10:30 AM
3.0charlie's Avatar
I highly suggest you read the thread again Raserei408, Mark never mentionned that the OP should use a 965 for that build. He was replying to b1lk1.
As far as PSU wattage, a 450W would be overkill for such a build - even with overhead...
Hydro-Quebec is salivating...
  #30 (permalink)
Old February 11, 2010, 05:22 PM
CraigRT's Avatar
Because most enthusiasts are anal with our hardware, we pick and nitpick the best of the best.
If you got her an OK mid range GPU, A, say, Athlon X4 620 and a quality AM3 board with a non-modular PSU because who cares what it looks like inside (again for her, not for you :P) and a great monitor with maybe a stylish new kb/mouse, whats for her not to like? You can make that cost way less too. Fast HD I agree with, they're not expensive (WD black)
my .02
i7 860 + Hyper 212
P55A-UD4P F14
8GB Mushkin Silverline
Powercolor 5870
Velociraptor 150
Seagate LP 2TB
Corsair AX750
Silverstone FT01B-W (HWC review case)
HEATWARE 45-0-0
My Cannondale <3
Build my PC! (Around $1000.00) Revisited. philthygeezer New Builds 10 February 14, 2010 05:01 PM
1000$ build belinik New Builds 17 December 10, 2009 09:36 PM
Build me a quite PC for $1000 min New Builds 23 March 28, 2009 12:45 PM
$1000 Build For a Friend geokilla New Builds 19 February 21, 2009 07:56 AM
Build my PC! (Around $1000.00) philthygeezer New Builds 57 October 31, 2008 01:40 PM
