  #21 (permalink)
Old February 6, 2010, 08:54 PM
Raserei408's Avatar
Quality components, overclocking, voltage tweak
"If dancing is sure to result in failure then you must dance anyway."
Lo Mein said that, and I think he knows a little more about dancing than I do pal, because he invented it! Then he perfected it so that no man could best him in the club of honor.
Then he used his prize money to buy two of every whore on Earth. Then he herded them all onto a boat, then they all beat the crap out of every single one of him.
  #22 (permalink)
Old February 6, 2010, 09:00 PM
rjbarker's Avatar
1. Warranty
2. Customer Support
All performance GPU's can be OC'd to some extent.
Voltage Tweaking and BIOS Flashing ( in many cases VOIDS the Warranty).
Firestrike Extreme: 21.452
MARK 11: 32.530
  #23 (permalink)
Old February 6, 2010, 09:18 PM
Raserei408's Avatar
But XFX's ATI cards tend not to OC as high as other brands. This is especially the case with MSI's cards, which have the voltage tweak I mentioned.
As for BIOS flashing to get voltage tweak, if the warranty is the primary reason to go with XFX, why would you risk it by flashing the BIOS and voiding your warranty?
  #24 (permalink)
Old February 6, 2010, 10:51 PM
Soultribunal's Avatar
OKay Thread Cleaned and Back on Topic.
Ras - Okay I do Agree for gaming an SSD won't really create a noticable difference. And for the Record I have this Mod title for a reason. Reliability, Responsibility and dedication to the Forum and its Members. With Great Power, comes great Responsibility.
As for everything else, lets keep it clean. If you have an issue , please report it to one of the staff via A PM and not ruin a thread that is designed to help another member.
Regards,
ST
www.realhardwarereviews.com
  #25 (permalink)
Old February 7, 2010, 11:02 AM
BT!'s Avatar
BT! BT! is offline
sure it does, i load maps way faster than most people, in cod4 i load a map in 1 second, in bfbc2 i load so quick i'm already parachuted in, on an atv and 1/2 way to the enemy side of the map before anyone else has loaded the map and spawned.
  #26 (permalink)
Old February 7, 2010, 11:15 AM
MarkOne's Avatar
  #27 (permalink)
Old February 7, 2010, 09:20 PM
Raserei408's Avatar
But it won't run the game at any higher frame rates, the point I'm trying to make. Look at it this way; is it worth it to sacrifice FPS for an SSD when you can easily add an SSD 6 months from now?
  #28 (permalink)
Old February 7, 2010, 10:43 PM
Haha, true. I think I load pretty fast by my standards at least even BF:BC2 Maybe not quite as ninja quick but I can still get to their first bomb point with the tank without much resistance.
Seeking advice: Easy AM3 cooler CMetaphor Air Cooling 20 January 13, 2010 10:32 PM
seeking advice on new CPU cooler Polygon Air Cooling 5 August 20, 2009 02:58 PM
Seeking advice on part selection Mibs Water Cooling 26 February 8, 2009 02:52 PM
Seeking advice on new build Gellidius New Builds 8 December 13, 2008 12:08 PM
Seeking advice on multiple soundcard build / Will it work? Ironmonk Troubleshooting 3 December 12, 2008 01:46 PM
