Old February 6, 2010, 04:15 PM
Yep Corsair Dominators are too expensive. Go G.Skill for sure.
"What is the colour when black is burnt ?" - Neil Young
Old February 6, 2010, 04:25 PM
Soultribunal's Avatar
Originally Posted by MILITANT View Post
If i can help here ! I would suggest you change the following ..... Your operating system is costing you double, for what? Buy home premium for 130 ! Next why buy the I7 930 ? this is gonna cost you how much? Buy the 920 and overclock it to a 950 spec.. now your 5850 is a dumb purchase you can buy the 5870 for the same price if not 20 dollars more ! Dont buy the 5850 go 5870, or better yet the money that you have saved on your processor and your op system can be put into the 5970! bam ... and the Ram.... I personaly would suggest the corsair dominators .. the money you are looking at spending can be reallocated in a better fashion to provide you with a much more powerfull finished build! I suggest looking at several versions of this build until you find the one that suits your tastes the best! Dont get me wrong i am all about putting the money up for the better hardware but you cant go half way high end you gotta go smart high end! Your motherboard i own it and love it also the TRUE only gets good reviews but you might wanna try the corsair H50 i think they call it a closed loop cpu water cooler! no experience needed.
When we critque builds here, using phrases like that don't win you friends. This is the second time I've seen this from you in your two posts.
No more warnings.
ST
www.realhardwarereviews.com
Old February 6, 2010, 05:10 PM
MarkOne's Avatar
i will just a small comment here.... on a $ 2000 build :
find the place for a SSD ..we have few tread in the drive section to help you to choose one, and AkG is always happy to help for it..
Old February 6, 2010, 05:44 PM
Raserei408's Avatar
My feelings of SSDs:
Whipped cream on top of a good rig. They certainly make a computer feel faster (a lot faster) but they don't improve actual performance. It's not worth sacrificing quality of core components to add an SSD. Not to mention they're very easy to add after the fact; just buy one, hook it up, set it as the boot device, install the OS, boom.
"If dancing is sure to result in failure then you must dance anyway."
Lo Mein said that, and I think he knows a little more about dancing than I do pal, because he invented it! Then he perfected it so that no man could best him in the club of honor.
Then he used his prize money to buy two of every whore on Earth. Then he herded them all onto a boat, then they all beat the crap out of every single one of him.
Old February 6, 2010, 05:47 PM
Sure they do, as I am sure AkG our Resident SSD expert will say the general performance with the right SSD will make a major Improvement on your system as a whole.
Might not win you more 3Dmark score but VS a traditional Platter Drive it is worth it for Higher End Builds.
ST
Old February 6, 2010, 05:50 PM
Raserei408's Avatar
What I'm saying is an SSD won't make your games run better, help decode videos, etc.
Old February 6, 2010, 06:09 PM
Hmm, I sort of agree with Raserei408 in that an SSD for me right now is more like icing on the cake. I would love one, but I don't think I'm quite ready to make the jump and get one yet. As for the ram, I think I will settle for the G.skills for the price / performance ratio . I'll browse around for that Zalman Flex too, thanks Raserei408!
I havn't had much experience from other video card vendors since I've been on the XFX wagon for quite a while, so who would you recommend between Sapphire, Diamond, and Powercolor if I'm going for the 5850?
Also, I guess the last thing I'm really sitting on the fence is either the UD5 or EVGA X58 mobo. When it comes down to that, is it just a brand / software preference since they both seem excellent.
Old February 6, 2010, 06:29 PM
Raserei408's Avatar
Honestly for the most part video card vendors don't make a big difference. I usually just say go with whatever's cheapest (unless a third-party cooler is involved). If I had to choose a brand ATM for ATI 5xxx cards I'd probably say MSI.
  #19 (permalink)
Old February 6, 2010, 06:58 PM
And if you plan on getting just one hard drive the larger SSDs are more expensive. Can't go wrong with your original choice. Pretty fast and tons of room.
  #20 (permalink)
Old February 6, 2010, 06:59 PM
Warranty, warranty, warranty.
Seeking advice: Easy AM3 cooler CMetaphor Air Cooling 20 January 13, 2010 10:32 PM
seeking advice on new CPU cooler Polygon Air Cooling 5 August 20, 2009 02:58 PM
Seeking advice on part selection Mibs Water Cooling 26 February 8, 2009 02:52 PM
Seeking advice on new build Gellidius New Builds 8 December 13, 2008 12:08 PM
Seeking advice on multiple soundcard build / Will it work? Ironmonk Troubleshooting 3 December 12, 2008 01:46 PM
