Old January 17, 2010, 01:20 PM
Default Help with a I7 920 build
Time to replace my 5 yr old desktop. Looking at an all around system not really a gamer maybe some HT use in the future. Here's what I'm looking at so far.
I7 920 (no over clocking for now).
Gigabyte X58A-UD5
Coolmaster CM690 II
WD 1TB Caviar black
Gigabyte HD5670
Corsair TX750 watt
OCZ Gold 6GB DDR3
Do I need a CPU cooler? open to suggestions especially on the power supply, memory and video card.
I'm at home with a broken leg so I need something to work on. Thanks.
Old January 17, 2010, 01:34 PM
SugarJ's Avatar
Your parts list is fine, although I tend to lean to Corsair or G.Skill for memory. I would put a Coolermaster Hyper 212 HSF on even if you aren't OC'ing. It will drop your load temps significantly, it's under $30, and will give you headroom to OC if you want.
Coolermaster Hyper 212 Plus Direct Touch 4 Heatpipe Heatsink AM2 AM3 LGA1366 LGA775 LGA1156 120MM - DirectCanada
Old January 17, 2010, 01:45 PM
Thanks for the input on the cooler I'll look into getting one. I wasn't sure on the ram I see NCIX has a 6gb Corsair kit on sale.
Old January 17, 2010, 01:49 PM
SugarJ's Avatar
The OCZ Golds they have on sale are actually faster than the Corsair ones on sale. DDR3-1600 8-8-8-24 vs. DDR3-1333 9-9-9-24. Nothing wrong with OCZ, I just hate the MIR run-around.
Old January 17, 2010, 02:02 PM
I hear you seems like you have to wait 6 months to get your $ back.
Old January 17, 2010, 09:49 PM
Raserei408's Avatar
Usually takes a couple months, but not nearly six. Got mine from XFX in ~6 weeks, but I never got my one from Xigmatek. MIRs are nice, but I don't typically count them in the price of an item.
"If dancing is sure to result in failure then you must dance anyway."
Lo Mein said that, and I think he knows a little more about dancing than I do pal, because he invented it! Then he perfected it so that no man could best him in the club of honor.
Then he used his prize money to buy two of every whore on Earth. Then he herded them all onto a boat, then they all beat the crap out of every single one of him.
Old January 18, 2010, 02:21 PM
Darksword's Avatar
Why such a large power supply when you're only running a non-overclocked i920 and a 5670? Also, you're spending a lot on a mobo considering you're not overlcocking/gaming. Take a look at this Gigabyte board that still offers USB 3.0 and SATA 6G for about $50.00 less.
Old January 20, 2010, 12:35 PM
I did switch power supplies but stuck with the mo.board.
Here is what I ordered today from NCIX. Maybe over kill in some area's. Should be a good rig though.
Thanks for every ones help.
31000 Western Digital WD1001FALS Caviar Black 1TB SATA2 7200RPM 4.2MS 32MB 3.5IN Dual Proc Hard Drive OEM (ADA)
34543 Gigabyte EX58-UD5 ATX LGA1366 X58 DDR3 3PCI-E SATA2 Sound 2GLAN 3-WAY CrossFireX SLI Motherboard (ADA)
41337
Coolermaster Hyper 212 Plus Direct Touch 4 Heatpipe Heatsink AM2 AM3 LGA1366 LGA775 LGA1156 120MM (ADA)
35710
OCZ Gold OCZ3G1600LV6GK 6GB DDR3 3X2GB DDR3-1600 PC3-12800 CL 8-8-8-24 Triple Channel Memory Kit (ADA)
45065 Sapphire Radeon HD 5750 700MHZ 1GB 4.6GHZ GDDR5 PCI-E 2XDVI HDMI Display Port Lite Retail Video Card (ADA)
34598
Intel Core i7 920 Quad Core Processor LGA1366 2.66GHZ Bloomfield 8MB LGA1366 4.8GT/S (ADA)
42532 Corsair Professional HX650W 650W ATX 12V 52A 24PIN ATX Modular Power Supply Active PFC 120MM Fan (ADA)
49226
Coolermaster CM 690 II Advanced ATX Mid Tower Case Black 4X5.25 1X3.5EXT 6X3.5INT *No PSU* (ADA)
Old January 20, 2010, 01:05 PM
Of course a bunch of prices dropped right after I ordered? Doh
Old January 20, 2010, 01:07 PM
lowfat's Avatar
Any reason you went w/ the EX58-UD5 over the X58A-UD5?
The Crippled God WIP
Queen of Dreams WIP
Big Lian Li
Complete
Forever Alone Complete
New I7 920 D0 Build and OC memeboy Overclocking, Tweaking and Benchmarking 3 January 4, 2010 04:57 PM
920 Build from NCIX Syntax New Builds 12 September 11, 2009 09:31 PM
~$2000 i7 920 Build FreeKnight New Builds 7 July 9, 2009 09:46 PM
i7 920 Build Zankras New Builds 9 July 5, 2009 09:33 PM
Build for my shiny new i7 920 Veeediot New Builds 3 December 29, 2008 06:27 PM
