Old January 16, 2010, 12:27 AM
Default what fans should i get
so i was searching the yellopages today looking for a computer case, and ending up buying two becuase the guy charge me $5 each to get rid of them and they have not even been used. the one im using is mettalic green and i think it looks to be an apevia. There are four places for 90mm fans, i have two fans one of which is a blue led one. so what fans should i get that are cheap, also should i drill a hole on the top for a 200mm case fan? and on the side a 120mm or vice versa?
Old January 16, 2010, 11:53 AM
Raserei408's Avatar
For smaller fans, I'd recommend Yate Loon. They're solid fans, and (most importantly) they're dirt cheap. As for the 200mm and 120mm placements, do you have a really high-end GPU / are you OCing your GPU? If so, I'd say put the 200mm on the side. However, if you have a hotter CPU that you're OCing, put it on top.
"If dancing is sure to result in failure then you must dance anyway."
Lo Mein said that, and I think he knows a little more about dancing than I do pal, because he invented it! Then he perfected it so that no man could best him in the club of honor.
Then he used his prize money to buy two of every whore on Earth. Then he herded them all onto a boat, then they all beat the crap out of every single one of him.
Old January 16, 2010, 12:29 PM
Kayen's Avatar
Drill the holes, and install 120mm fans. Best airflow / price ratio.
Old January 16, 2010, 09:13 PM
i was looking at the delta fans becuase they are like leaf blowers, lol any good sites to buy from.
Old January 16, 2010, 10:35 PM
Great fans if you're deaf to start with.
Old January 16, 2010, 11:14 PM
yeah so i heard, but they have some sick airflow, i dont care about noise though i have some decent koss headphones so its all good.
Old January 17, 2010, 09:49 AM
Raserei408's Avatar
You say you don't care about noise, but imagine playing games with a chainsaw next to you. If you can deal with that, the Deltas are great. If not, stay the f--- away.
Old January 17, 2010, 07:54 PM
ah man it couldnt be that bad, besides i got those decent headphones they are full size. i also bought a cooler master 120mm green led fan for the side, its a 90cfm are they any good?
Old January 18, 2010, 08:00 PM
CroSsFiRe2009's Avatar
Pretty sure any people even living with you will be deaf too. If you want cheap, go with Gelid Silent 12's you can pm them pretty cheap but not the most airflow. If you want better fans, Scythe S-flex 1200 or 1600rpm one's are extremely good or even Slipstreams. Yate loons arent a bad choice either.
Old January 18, 2010, 11:05 PM
i might get another scythe, but i allready bought the leafblower so i stuck with it hahaha
[FS] WC and Fans Jackquelegs Buy/Sell & Trade 16 December 8, 2009 09:47 AM
What fans to use Fudd Rucker Air Cooling 12 November 5, 2009 10:51 PM
[FS] New Zalman fans, used Scythe and blue LED fans mhw100 Buy/Sell & Trade 15 June 22, 2009 02:32 PM
S-Flex Fans 486 Air Cooling 3 March 30, 2009 09:49 AM
Anyone have one of these fans? Realityshift Air Cooling 11 March 12, 2009 08:44 PM
