Old January 15, 2010, 06:59 PM
Default Need help to choose LGA1366 mobo
Board will be paired up with an i7 920 D0 and will be OCed on air to 4.0 Ghz (at least I'll try). Which board is solid and great in general?
Budget is around $300 or less. Also which RAM would go well with it?
Thinking to throw a 750W modular Seasonic PSU in there, will be using my XFX 4890.
Cooler will prolly be the CM Hyper 212+.
I game at 1920x1200.
Thx guys!
Old January 15, 2010, 07:04 PM
This and this are both great boards. The X58A-UD5 is new, so no user review yet. But I have the older version of it without USB 3.0 and SATA 6Gbps (EX58-UD5), and it is an awesome board. 10 SATA ports FTW!
Old January 15, 2010, 07:13 PM
ZZLEE's Avatar
Default EVGA
old now but i like mine Newegg.ca - EVGA E758-A1 3-Way SLI (x16/x16/x8) LGA 1366 Intel X58 ATX Intel Motherboard - Intel Motherboards If you go Evga Make sure to get A1 product and register it within a month of puchase. Nice warinty.
Old January 15, 2010, 07:30 PM
lowfat's Avatar
The X58A-UD5 or the X58A-UD3 would be my choices. The UD3 is quite a bit cheaper and doesn't loose all that much for features.
Newegg.ca - GIGABYTE GA-X58A-UD3R LGA 1366 Intel X58 SATA 6Gb/s USB 3.0 ATX Intel Motherboard - Intel Motherboards
The Crippled God WIP
Queen of Dreams WIP
Big Lian Li
Complete
Forever Alone Complete
Old January 15, 2010, 08:05 PM
martin_metal_88's Avatar
Well the UD3 will be nice and perfect if you don't need E-sata, then get it. If you need it UD5 is a hard to beat and the EVGA is also pretty nice.
Old January 15, 2010, 08:56 PM
I'm leaning towards Gigabyte or eVga, that Asus just looks ugly in my opinion ... well Gigabyte's colour schemes aren't very sexy either. lol
I'm still debating, in the end I should probably go with the cheapest thing that gives me what I need and it will all be in a Storm Sniper so there is no window to see what's inside the case so looks shouldn't count too much.
The OCZ Gold RAM 3x2GB any good? Other recommendations?
Thx for the input guys!!!
Old January 15, 2010, 09:03 PM
3.0charlie's Avatar
Asus Rampage II Gene. Oc'ed my 920 C0 like a champ to 3.9 w/1.30V Vcore. Using air, load temps were 70C using a Noctua D14 with 3 YLs.
Top notch board.
Hydro-Quebec is salivating...
Old January 15, 2010, 09:06 PM
ZZLEE's Avatar
Default IDE port,PS2
If you realy overclock an IDE drive works better at high overcloks. Stata has voltage problems at the extreems. The ps2 Keybord can be usefull also on the Evga if you overvolt.
Old January 15, 2010, 09:15 PM
MarkOne's Avatar
a link to the 3.0 suggestion
NCIX.com - Buy ASUS Rampage II Gene mATX LGA1366 DDR3 X58 2PCI-E16 PCI-E4 PCI GBLAN CrossFire SLI Motherboard - RAMPAGE II GENE In Canada.
Old January 15, 2010, 09:26 PM
Top notch board.
I heard the Rampage II Gene's IOH gets really hot under load, is it true?
help me choose muffler CPU's and Motherboards 5 October 6, 2009 05:01 PM
Please help me choose... somecanadianguy New Builds 127 March 30, 2009 07:36 PM
Which would you choose? These 2 bufa CPU's and Motherboards 19 February 20, 2009 09:14 AM
FS-s939 X2-3800, OCZ ram, Ac Freezer 64 Pro, ASRock mobo, DFI mobo, Asus mobo..more stoanee Buy/Sell & Trade 14 June 7, 2008 06:24 PM
What to Do - which to choose janes780 RAM 5 December 10, 2007 12:34 AM
