A build to increase my PPD Before I press the oder now, I will like to have your comment on this, I plan to run only GPU client on it Qty.Product DescriptionSavingsTotal Price1http://c1.neweggimages.com/ProductIm...130-223-02.jpg MSI 790FX-GD70 ATX AMD Motherboard Item #:N82E16813130223 Return Policy: Limited Replacement Only Return Policy $184.991 http://c1.neweggimages.com/ProductIm...103-680-02.jpg AMD Phenom II X2 550 Black Edition 3.1GHz Socket AM3 80W Dual-Core Processor Item #:N82E16819103680 Return Policy: CPU Replacement Only Return Policy -$5.00 Instant $109.99 $104.991 http://c1.neweggimages.com/ProductIm...211-410-02.jpg A-DATA Gaming Series 4GB (2 x 2GB) 240-Pin DDR3 SDRAM DDR3 1333G (PC3 10666) Desktop Memory Item #:N82E16820211410 Return Policy: Standard Return Policy $94.994 http://c1.neweggimages.com/ProductIm...127-464-03.jpg 4 of them MSI GeForce GTX 260 N260GTX Twin Frozr OC Video Card Item #:N82E16814127464 Return Policy: VGA Standard Return Policy -$15.00 Instant $819.96 $759.961 for 4 of them http://c1.neweggimages.com/ProductIm...371-032-01.jpg Antec TruePower Quattro Series TPQ-1200 1200W Continuous Power Power Supply Item #:N82E16817371032 Return Policy: Standard Return Policy $309.99 Grand Total:$1,454.92 |
All is fine except the PSU: if I remember correctly the 1.2k was not that good. I used the BFG 1200W when I used to GPU fold with quad GX2s, and it ran damn fine - was cheaper too. Deadthings is now the proud owner of the PSU... |
The PSU is the only thing I was not so sure.... I choose the Antec because it have 8 x 6 connectors for the card ( if I count the 6+2 ) , I guess I can use molex adaptor for the 2 missing on the BFG , all true I put the Antec in the list of New Egg for simplicity , I have an other source for it at $ 238 .... |
I used 2 of those to split the PCI-e power for the GX2s. NCIX.com - Buy Works 6 Pin PCI-E Splitter Cable - 1 PCIe Female 6 Pin to 2 PCIe Male 6+2 Pin (6 or 8) - CB-6M-68F2 In Canada. |
those work just fine, but make sure you're using a single 12v rail PSU. multi-rail psus don't normally take well to molex and other PCIe adapters. Or get a silverstone :thumb: |
Get a Strider Plus 1200W. You'll love it. ST |
Mark don't you have enough computer? Seem's fair to me but, I would downgrade the PSU to a good 1000 or 850W and put a better CPU and run the CPU client to. with bonus you get more PDD compare to a GPU. |
The BFG has 1 rail per PCI-e cable, hence why it could run all 4 GX2s. |
If you want the best PPD per cost your best bet would likely to go w/ a i7. A Bigadv can pull 22,000 - 25,000ppd PPD on a ~4GHz i7. |
I'm here to lissen guy, tell me what to build ( but Cm , no 24 cores pls :haha:) |
| All times are GMT -7. The time now is 11:11 PM. |
