Old January 9, 2010, 08:00 PM
geokilla's Avatar
Everything looked good until we got to the GPU. Stick with custom building it yourself.
If you're wondering if it's hard to build your own computer, it's easy. I built my first and current one that I'm using and it took only a day. Could've finished it quicker if I realized I was installing the Vendetta 2 wrong.
Old January 9, 2010, 08:53 PM
Perineum's Avatar
Yeah, I'd build it yourself if you think that you're a patient meticulous individual. It's not something you can rush your first time. Build it and come on this thread asking questions, we'll help
Old January 9, 2010, 10:55 PM
JD JD is offline
Originally Posted by mr_syn View Post
Thanks for all the input guys. I live in Toronto, Ontario, I don't think they
have any stores here
There are many stores in or around Toronto.
Canada Comptuers is the main one IMO. Then there's Infonec, PC Village, TigerDirect, and many other little small shops.
Old January 10, 2010, 05:47 PM
Raserei408's Avatar
Never buy a gaming PC. They will always dramatically overcharge you. Honestly, that PC's not even a little worth it.
The computer I'm using is the first computer I've ever built. It sounds scary, but it's actually not that hard if you know what you're doing. Just read some guides and watch some relevant Youtube videos. It's actually pretty hard to screw up, you just put everything in the only place it can fit. Except front-panel headers. Those can be a bitch.
"If dancing is sure to result in failure then you must dance anyway."
Lo Mein said that, and I think he knows a little more about dancing than I do pal, because he invented it! Then he perfected it so that no man could best him in the club of honor.
Then he used his prize money to buy two of every whore on Earth. Then he herded them all onto a boat, then they all beat the crap out of every single one of him.
Building first rig austmart New Builds 8 June 30, 2009 11:41 AM
New Rig +/-800$ T.t74)Rocky New Builds 19 November 6, 2008 05:19 PM
New to PC gaming. Requesting help building a rig. Zippoh New Builds 19 November 2, 2008 10:35 AM
Building New Rig swiftk1 New Builds 7 August 27, 2008 02:16 PM
Building a new rig, need help(im new) NoobLordSpud CPU's and Motherboards 22 July 10, 2007 07:53 AM
