Old January 8, 2010, 07:40 AM
Default Power supply for this system
I am about to upgrade my main system, which sits in an Antec P180 case.
The power supply is an Enermax Liberty 500W unit. I am looking for advice - is this sufficient for the components listed below?
These components are all purchased, with the last few bits arriving today according to Purolator's web site:
Motherboard: ASUS Maximus III Formula
Memory: 4 pieces of DDR 1600 2Gb, total 8Gb
Video: XFX 5770, driving an Acer 24" and a Samsung 17" (1280x1024)
Other cards: PCIx 1x audio supplied with MaxIII board
CPU: i5, hopefully pushed to 4Ghz or whatever can be stable
CPU Cooler: Venomous X with two 120mm Noctura fans
Hard drive:
- Velociraptor 300Gb
- Seagate IDE 320Gb
- Seagate 1.5Tb SATA
(the IDE drive will be removed a week or two after the build, once apps have been moved from XP to Win7)
Optical drives:
- Plextor PX716 DVD-RW
- LG 22x DVD-RW
- Plextor 5224 CD-RW
- Plextor Blu-Ray reader (model 310)
Internal fans: four 120mm (two at top, one front of upper drive bay, one in lower drive bay/power supply area)
I don't do hardly any gaming, but do some video and photo editing. This rig is intended more for future proofing (for whatever that term means theses days!) and smooth operation and a bit of experimenting, not raw horsepower.
Will a 500W power supply be sufficient?
Thanks in advance!
Old January 8, 2010, 07:48 AM
Finch's Avatar
if it would be my setup i would choose something like a corsair tx750w or tx850w to have some headroom plus they have plenty of amps. Those are high quality psu's and they have 5 years warranty on them
If you are an overclocker please come and participate to the HWC Benchmarks Competitions, look for the stickies.
Old January 8, 2010, 08:17 AM
Thanks for the setup!
However, since I already have the Liberty 500W installed, the question is - will this be sufficient?
I guess it should be broken into two questions:
1> will the 500W power supply be sufficient to run this system stock, no overclocking, for daily use?
2> will the 500W power supply be sufficient if the system is overclocked and pushed?
I have no trouble upgrading the power supply, but I have a real problem buying gear when the existing gear will work. That is why I am looking for advice.
Thanks!
Old January 8, 2010, 08:28 AM
MarkOne's Avatar
Just forget the 500 W Idea
with your bunch of dvd and the 4ghz OC at something around 1,4 volts ( mine is at 1,31, but I want get generous) and with the calcul of the aging ... your PSU will not be new in 3 years... you need 606 watts. for 90% of the load. I don't like be tight , so 750w will be my minimum
Old January 8, 2010, 08:37 AM
misterd's Avatar
If you drop down the opticals and hard drives, you might get away with it for now. But as your power supply ages it may give you issues down the road.
#hardwarecanucks on irc.freenode.net
fiat justitia ruat caelum
Old January 8, 2010, 09:08 AM
The power supply has already been in use for two or three years, at least.
Hmm......guess I will have to see what Canada Computers has in stock.....
Old January 8, 2010, 10:55 AM
if you didn't have so many dvd drives i would say it would work. I'm really cheap so i know i would try it if i was in your shoes unless you got another pc to use that enermax in
Go to dell and check out the xps9000, it has a 450 watt psu. Build one(website, not really) of those online with as many option as possible and then make a comparison with all the stuff you have . keep in mind that dell is said to under rate their psu's so its likely closer to 500 watts
The Dell Online Store: Build Your System
Old January 8, 2010, 11:08 AM
MarkOne's Avatar
don't loose your time with the Dell web site, do like I always do use the Antec PSU calculator, but you have to learn how to use it, all true it's easy , just make the good choice, you say it will be OC at 4000, so put 4000, but it's the voltage that make watts, so you have to know the voltage, it's around 1,31 for a I5 750 , amd use the ageing also, your psu will not always be new.
Antec Power Supply Calculator
Old January 8, 2010, 11:50 AM
headsh0t's Avatar
eXtreme Power Supply Calculator
Old January 8, 2010, 01:06 PM
Great links, thanks guys. Nice to confirm that you are still on track every now and then, or before you upgrade a component.
[WTB] power supply 650+ power supply j-ronde Buy/Sell & Trade 1 March 31, 2009 09:45 AM
PC Perspective reviews 1000W BFG Tech PC System power supply Supergrover Reviews & Articles from the Web 0 February 22, 2007 09:40 PM
