  #21 (permalink)
Old January 11, 2010, 09:57 AM
Thanks for all the advice and links!
Ended up getting a Corsair 750HX, which seems to be running well.
However, I would not do that again - this power supply is longer than any one I have had before. Since it is going into an Antec P180 case, this matters - it means the cables are running into the space where the 120mm fan used to be in the bottom section of the case!
I never thought about this when picking up the power supply - Canada Computers also had the 650HX, but I have been unable to find any specifications for these units, to see what the physical size of each is.
  #22 (permalink)
Old January 11, 2010, 10:02 AM
Soultribunal's Avatar
Ahhh yes there is a Size difference on that one.
Your best best if Size matters , the Silverstone Strider Plus 750W (same specs as the corsair) is only 190mm Depth as opposed to the Corsair one.
I'd get that one instead.
ST
  #23 (permalink)
Old January 12, 2010, 09:31 AM
As they say, hindsight is 20/20.....
The Corsair is purchased and installed. Nothing wrong with it, so I was not going to return it. Just an inconvenient size.
  #24 (permalink)
Old January 12, 2010, 08:01 PM
are the silverstone's any good? i plan on getting a 600 watt for a quad core setup.
  #25 (permalink)
Old January 12, 2010, 08:08 PM
Most are, although some are mediocre. Which model are you looking at specifically?
  #26 (permalink)
Old January 12, 2010, 08:32 PM
Get this one, you won't be disappointed.
Very nice Enhance unit.
NCIX.com - Buy Silverstone Strider 750 Plus 750W Modular Power Supply ATX 24PIN 135mm Fan 60A 80+ Silver Black - ST75F-P In Canada.
ST
[WTB] power supply 650+ power supply j-ronde Buy/Sell & Trade 1 March 31, 2009 09:45 AM
PC Perspective reviews 1000W BFG Tech PC System power supply Supergrover Reviews & Articles from the Web 0 February 22, 2007 08:40 PM
