Old January 7, 2010, 11:44 PM
HumorusPrawn's Avatar
Default Watercooling Loop Help!
Hey all, I am building a loop and need some imput on how I should run it.
Should I go
Pump>CPU>Rad>Res>Pump
OR
Pump>Rad>CPU>Res>Pump
I thought that a good pressure from the pump to CPU would be good, but also thought that if I cooled the water before entering the CPU it would be better. But will water in the res get warm that much?
If someone has lots of experience with it I would love to hear their input.
BTW my parts for WC are:
Apogee GTZ
Switech MCP655
Thermochill PA 120.3
EK Multi Res 150
1/2 ID 3/4 OD tubing
Feser One UV Purple Coolant
Thanks!
Old January 7, 2010, 11:55 PM
res > pump > cpu > rad
Old January 8, 2010, 05:26 AM
Finch's Avatar
the loop order is not important because the water will eventually reach temperature equilibrium, as long as the res is before pump and also higher then the pump, it will be ok.
If you are an overclocker please come and participate to the HWC Benchmarks Competitions, look for the stickies.
Old January 8, 2010, 07:06 AM
gingerbee's Avatar
very right setup means very little in overall temps , but i run mine res>pump>rad>cpu then any others after that.
Old January 8, 2010, 08:40 AM
Raserei408's Avatar
I would say Pump > Rad > CPU > Res > Pump. I've never WCed myself, but the pump does heat the water a bit, so it's best to run it though the rad before it gets to the block.
Also, why are you using store-bought coolant? Distilled water with a bit of antifreeze will work as well and cost a lot less. If you want the coolant's color, I'm sure there are dyes you can buy.
"If dancing is sure to result in failure then you must dance anyway."
Lo Mein said that, and I think he knows a little more about dancing than I do pal, because he invented it! Then he perfected it so that no man could best him in the club of honor.
Then he used his prize money to buy two of every whore on Earth. Then he herded them all onto a boat, then they all beat the crap out of every single one of him.
Old January 8, 2010, 10:57 AM
Finch's Avatar
with many years of experience with watercooling i can tell you that eventually the water's temperature will be almost equal eveywhere in the loop no matter the order. you might get 1-2c difference at most. It is more important to use your energy on figuring a way to use less tubing as possible it will have a bigger impact on your temps then the order of you're parts in the loop
Old January 8, 2010, 11:06 AM
Varroa's Avatar
Res should always be before pump to make sure the pump doesn't run dry when you are first setting it up. Other than that it really doesn't matter.
GAMER: Win10 Pro x64, I7 3770K (4.7Ghz) (corsair H110i), Asus P8Z77-V Pro, EVGA GTX 1080 FTW, Gskill 2 x 8 GB DDR3 1600Mhz, Crucial M4 120 GB + 256GB, Crucial M500 480 GB SSD, Mx 500 SSD, HX750W, Sound blaster Z, & Fractal Design Arc MIDI R2
Lenovo Ideapad Y510p: i7-4700MQ 2.4GHz (undervolted by 80mV), 16GB DDR3L-1866MHz, Intel GMA 4600HD / SLI'ed Nvidia Geforce GT 755M 2GB GDDR5, 240 GB Crucial SSD, 128GB M.2 SSD, 15.6" HD+ Glossy LED
Loop help Lpfan4ever Water Cooling 12 September 22, 2009 06:22 PM
Advice/comment on my watercooling loop LC0g Water Cooling 29 May 28, 2009 05:53 AM
WaterKegIII Extreme external Watercooling unit, Watercooling stuff Apollo4g Buy/Sell & Trade 9 June 9, 2008 09:49 PM
Expanding My Loop ChuckleBrother Water Cooling 2 May 11, 2008 05:57 PM
My Soon-To-Be loop Kopi Water Cooling 5 October 23, 2007 12:49 PM
