Old December 30, 2009, 09:12 AM
just done thinking - dangerous I know, the misses tells me not to - there is 170mm of space between the mounting board in the case and the fan guard. however, there is the mobo and spacers and cpu depth to account for - struggling here to find anything on scan may have to go watercooling route !!!!
help me Obiwon
Old December 30, 2009, 09:19 AM
TokeR's Avatar
The Corsair H-50 Water cooling setup looks nice and small and very neat, not sure how it performs because I don't own one but I have heard it performs just as well as most of the high end air coolers. I would look into it if I were you.
Good Luck.
Old December 30, 2009, 09:24 AM
Hey TokeR,
thanx matey. that cooler looks sweet too.
cool name you got there - and a cool build too. Would love a 300 series card to go with this build. by the time i have done this they will prob be out and i will be selling my 260.
steve
Old December 30, 2009, 09:33 AM
hey,
this one?
CWCH50-1 - Corsair H50-1 Hydro Series High-performance CPU Watercooler,
http://www.scan.co.uk/Products/Corsair-H50-1-Hydro-Series-High-performance-CPU-Watercooler-LGA775-1156-1366-AM2-2plus-AM3-NEW
I have never messed with water cooling, but this looks simple enough? are they easy to mount and where do i put the radiator? also does it come with everything i need?
cheers
steve
Old December 30, 2009, 09:35 AM
TokeR's Avatar
Thanks mate, cant wait for the 300 Series to come out either hopefully by then I will have enough cash for one or two purchasing the rest of my build will bring me down for a while lol.
Good luck with your build.
EDIT: Thats the one, it is also a very easy to install water cooling loop I would imagine easier than a few of the bigger air CPU coolers. it's a 120mm Radiator & fan so you should be able to mount it on any 120mm exhaust.
This video should help:
YouTube - Corsair Hydro H50 Water Cooling System - Wish List Series
Last edited by TokeR; December 30, 2009 at 09:39 AM. Reason: Answering a question.
Old December 30, 2009, 09:45 AM
hey thats great thanx matey,
have fun
steve
Old December 31, 2009, 05:57 AM
Hi guys,
Thanx for all you help - I have ordered the H50 corsair watercooler. will mean another week or so till its all up and running due to the holidays here, but seems well worth the wait. thanx again
happy new year Canuck dudes
steve
Old January 5, 2010, 12:15 PM
Hey,
my new h50 cooler just turned up. I have managed to stick one of my fingers in the pre-applied thermal silver. i have smoothed it out a little with some clingfilm. does this matter? should i clean it off and re-apply new stuff or will it be ok.
cheers guys
steve
  #19 (permalink)
Old January 5, 2010, 12:37 PM
martin_metal_88's Avatar
It will be ok, Or you can clean it and apply better paste like AS5 or IC24.
  #20 (permalink)
Old January 5, 2010, 12:54 PM
ok thanx man,
right lets get me hammer and i can start
Cooler Master Hyper 212 Plus CPU Cooler Review Comment Thread AkG Air Cooling 268 April 16, 2010 03:23 PM
Cooler Master Hyper N520 CPU Cooler Review Comment Thread AkG Air Cooling 3 June 8, 2009 07:54 PM
HALP! i7 build issues! ImmaPC Troubleshooting 12 February 7, 2009 06:21 PM
My new Cooler Master 932 Build darius_m5 Case Mods, Worklog & Gallery 20 September 24, 2008 10:54 AM
Another peculiar GPU cooler from Cooler Master: CoolViva Pro Review by X-Bit Babrbarossa Reviews & Articles from the Web 7 March 19, 2007 04:19 AM
