Old December 26, 2009, 07:36 AM
jcmaz's Avatar
I say Antec 650W for ~59 @ NCIX. NCIX.com - Buy Antec Earthwatts 650W Power Supply ATX12V V2.2 EPS12V Active PFC 80PLUS 120MM Fan - EA650 In Canada.
-Plato
Old December 26, 2009, 08:26 AM
im just using a arctic cooling alpine 64 cheap cheap heatsink...tbh im thinking the stock heatsink that came with the 550be is maybe as good..... if not better?
after changing it i didnt notice any temp drops more than 1 or 2 degrees at full load...im still deciding what hs to try next, needs to be small enough to fit into my HTPC tho....then i will try for better clocks or may drop cpu in another board under a TRUE i have here just to see what chip will do....
http://valid.canardpc.com/show_oc.php?id=932179
"Be so good at what you do that you cant be ignored"
Old December 26, 2009, 11:34 AM
Helix's Avatar
The Corsair HX650 is on boxing day special at NCIX... $25 off is nothing to scoff at.
NCIX.com - Buy Corsair Professional HX650W 650W ATX 12V 52A 24PIN ATX Modular Power Supply Active PFC 120MM Fan - CMPSU-650HX In Canada.
As I remember, it's a re-branded Seasonic. However, Corsair slaps a 7 year warranty on it. It's also modular, so less crap sitting in the bottom of your case.
Old December 26, 2009, 02:35 PM
Hey guys! I really appreciate all the advice I'm getting! This is what I'm considering right now to go with. AMD phenom II x2 550BE(110$), asus m4a79t deluxe (150$), g skill ripjaw ddr3 1333mhz CL7 memory(100$), silverstone raven rv01(210$), antec earthwatt 650watt power supply(60$). All are before taxes. Please advise! :)
Old December 26, 2009, 04:29 PM
Soultribunal's Avatar
That looks good to me mate.
ST
Old December 26, 2009, 04:50 PM
i agree with ST looks good :)
Old December 27, 2009, 05:59 AM
Alright sweet! Thank you all that helped! Couldn't have done it without you guys!
Tags
am3 , gaming , phenom
Building a gaming computer help xargon805 New Builds 22 December 22, 2009 08:40 PM
Building a computer naked? Shade340 Off Topic 56 June 22, 2009 11:16 PM
Building computer for brother! Hermesˇ˘ New Builds 60 December 11, 2008 02:22 PM
Building a new computer - FINALLY DONE! Hermesˇ˘ New Builds 38 November 14, 2008 07:51 PM
First attempt at building a computer! fawconpunch New Builds 6 June 28, 2008 07:42 PM
